Frigidaire GLTF1240A Front Load Washer Logo
Posted on Mar 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No high speed spin.Just replaced bearings and shocks last week and was working OK. Now this.Probably should have just bought a new one if the speed control needs replacing,What to do?
  • 10 more comments
  • vancej Mar 06, 2011
    ok what do I do next
    No blinking lights.It does not have a display to show any error codes.
    It is about 7-8 yrs old.
    all other functions seem fine. It just doesn't speed up in the spin cycle
    it just keeps tumbling slowly one way and then the other
    it only has a door lock light. No final spin light.
    wondering if their is a way to test the speed control unit
    as think they are quite expensive and don't want to buy
    one on spec.
    I don't think so . If it is it's very slow and then when the spin
    cycle is almost finished it advances quickly to the final
    slow tumble back and forth for a couple of minutes then
    advances to off,
    is that the same as speed control. Attached to the bottom
    right rear when viewed from the front? anyway ro test it?
    Yes I was when I replaced the back half of the tub
    with the bearings. Everything was working fine for
    a week or so . Anyway I'll check it all again and try
    it one more time. If it still doesn't spin high speed
    I guess I'll have to buy the board. Would have been
    better to buy a new machine as now the parts have
    cost me almost as much.Win some lose some I
    guess.Anyway thanks for the help.
    Yes I will take it out after the next cycle if it's still not working
    which I believe will be the case. You can Email me direct
    [email protected] if you think of anything else
    Yes and no. As good as it gets I guess
    Ok thanks but since I live in Canada the shipping might be costly.
    I'll check prices locally and go from there
    Just checked their website.They do not ship internationally
Anonymous
Level 2:
Guru:
  • Expert 262 Answers
  • Posted on Mar 06, 2011
Anonymous
Expert
Level 2:
Guru:
Answers
262
Questions
0
Helped
59885
Points
684
Hello....My name is Keith.....Please give me one moment and I will start to address the issue.
Thank You....
  • 9 more comments
  • Anonymous Mar 06, 2011
    STill looking at the print.....are all other functions operating? Any error codes? Lights blinking?
    If so what are they?
    Will the final spin light come on?
    Changing out the bearings and shocks tells me we had a lot of vibration going on in there....not unusual for some type of electronics to go bad. Solder joints,wires,wiring connections etc.
    Looks as if the speed control unit may be bad.
    Let me check further.....
    When it is suppse to be in high speed is the timer advancing?
    That is the next step if the timer is advancing
    Sorry.buddy....print indicates Motor control unit.
    Everything else works....timer is advancing, speed switch is made (open)
    Only thing left.....Motor control unit
    Not unless you can jump out the circuit on the board....but we would need the schematic for the board to do that.
    Here is the link to the part you need. You can get to it by taking off the back panel....should be on the left hand side when facing the back.Lower left hand corner.
    Click on the link http://www.searspartsdirect.com/partsdir...
    Part number four on the drawing
    You were back there working right? Check all the wire connections back there
    I hate giving bad news like this.....I'll continue to check the print....but I dont see how we can check the board.....Maybe take it out and look at it....look for burnt marks....broken solder joints.
    Repairclinic.com has a 1 year no questions asked return policy on all of their parts. They are a little pricey but you cant find that type of warranty anywhere. Even if your machine goes down again in the next year, and you buy a new one....send the board back with receipt and get your 100% refund.
1helpful
2answers
Everytime i hit a little bump my tured sqweaks an it knocks around the front tire. I dont know if its my bearings or ball joint or if i need new shocks. Can some one help pin point the issue.
  1. Shock absorbers (shocks) dampen out the spring motion. Go to each corner of the car and "bounce" the car. If it goes down, up, and stop,s the shock absorber at that corner is OK. If it goes down and up any more than that, the shock is bad.
  2. Jack up one front wheel. Pull on the top of he wheel and push in the bottom, and then the reverse. Back and forth. If it moves much it could be the ball joint.
  3. Rotate the tire slow and listen for a grinding noise and try to see if the wheel is unsteady while turning. If so, the bearing needs to be replaced.
  4. If the bearing seems OK but the tire moved (step 2) you probably have a ball joint problem.
NEPTUNE WASHER WILL NOT SPIN UP TO SPEED ON LAST CYCLE
sounds to me to be the programmer (mine went down last week) i bought a new machine as the part was a joke cost wise. if its old your probably find that other things will go wrong soon. now i have a fresh 3 yr warranty. would advise the same for you
I have a gleh1642fs4 model that drum will not spin?
I have a GLEH16242 Frigidaire/Electrolux stacking washer/dryer. The main bearing went out on the washer. I did the expensive fix of replacing the outer drum/bearing assembly in hope of nothing going wrong. Everything went together well, but now it won't go into high speed spin. It does if I have no clothes in it, but as soon as I introduce clothes it only does the 'medium spin' but never advances to the high. I've changed shocks, confirmed the door switch is working properly and double checked level. Even placed it on a big thick sheet of plywood in hops of stabilizing it more. It does have a wobble to it when it starts spinning, but when it kicks into medium spin, is smooths out.
1helpful
We have a Samsung 61 inch DLP tv. That started buzzing a few weeks ago when it was turned on. At first it only lasted a few seconds. Kinda sounds like a bad barring, Then this last week it began to last...
Highly likely that the sound was coming from the bearing in the color wheel assembly. When the bearing fails, the color wheel cannot spin at the correct speed, and because the speed is measured by the control board, the TV will shut down.
If you can handle a screwdriver - entire color wheel assembly can be replaced for about $100 and 30 minutes of your time.
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
10helpful
3answers
Whirlpool Duet WFW9200SQ02 - high speed spin extremely loud!
I have the exact same washer, its also 2 years old, and this last week my bearings went bad too. I actually pulled my washer apart and replaced the stock el cheapo bearings with some better quality ones by Toyo. No, theyre not titanium, I'm a mechanic and I've never even seen titanium sealed bearings before. Not doubting they exist, but I highly doubt youll find them in any residential appliances regardless of make. Upon disassembly, I found what I believe is the issue with the seal, hair. Hair works its way to the drive shaft, slowly works its way into the seal, and then acts as a conduit for the water to enter the bearing cavity. Both sealed bearings eventually have thier grease forced out by water, and fail. This repair is time consuming, but it can save you a LOT of money. Whirlpool only sells a whole new rear tub, at a cost of $408 just for the part. I took it apart and found that the bearings are simply pressed into the steel hub on the rear tub half. I knocked them out, and a local bearings and drives shop had some replacements for me, for $20. I put it all back together, and its running fine. If you attempt this repair, make notes, and mark where everthing goes. You'll need to disassemble a substantial amount of the machine to get the tub assembly out. If youre not able to do the repairs yourself, I recommend buying a new washer, its just not worth spending $6-700 to have a shop do it.
My coleman 3 ton heat pump blows very little air
Check the blower capacitor and blower speed, you probably have a 3 or 4 speed motor make sure it's on medium high or high speed.
If these are ok then shut the power off to the indoor unit and pull the blower housing out so you can see the blower wheel, make sure it's clean and very carefully spin the wheel to see if it spins freely keep hands away from wheel while it's spinning, if it doesn't then the bearings are bad and you need to replace the motor.
When on its final spin cycle washer does not spin at its normal high speed. it is three weeks out of warranty! I can't see anything mechanically wrong, so i'm assuming it has a self destruct program! Will...
REPLACING THE CIRCUIT BOARD SHOULD BE YOUR LAST RESORT.YOU NEED TO CHECK THE MOTOR WINDINGS ON THE MAIN MOTOR IF THEY OK THAT CAN ALSO CAUSE THE MOTOR NOT TO SPIN TO ITS FULLEST ALSO CHECK YOUR CAPACITOR IS OK.GOODLUCK. MOAHMED
4helpful
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
