Mag Innovision lt456s 14" Flat Panel LCD Monitor Logo
Posted on Mar 06, 2011
Where does the adapter plug in on the lt-456s
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jul 28, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
2482
Points
9
1 Related Answer
Anonymous
  • 9 Answers
SOURCE: does lt-456s have volume
nope, no speakers
2answers
Printing problem with casio HR-100TM calculator
Make sure you have the right AC adapter plugged in. I have two Casio printing calculators of different sizes with two different adapters. Though the input plug fits either calculator, only one of them is meant for the HR-100TM
On smaller Proview monitor, model 468, there is not power cord.
On the Proview 468 and possibly the PL-456s and the PZ-456if you look at the end of the VGA chord that you connect to the back of the computer right in between the two screws is a power connector for a 12 volt power supply this is for the 468 I hope this helps with your dilemma on how it gets power. [email protected]
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
2answers
Can't write onto my card through adapter, only works through the phone. "write protected" keeps coming up. No lock on adapter.
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
>>>>DOWNLOAD FORMATTER CLICK HERE <<<<
1helpful
2answers
A Simple Power Adaptor Issue
see are u sure that cable is for that slot...
try to open it as slider or use some lever to open it
2answers
Lan network card not working
yellow mark signifies
Driver Problems
or
Hardware Resource /IRQ problems
Choose properties of the device on device manager for details
regards
-Mayank
Found this monitor in a rubbish bin and near a local rent-to-own place. no power supply. the monitor is a Mag Innovision LT-456s, model 468. it takes 12v DC, 2.5A power supply. any idea where i could...
Try maplins i got one the other days for £24.99 they have a sale on at the moment, thats if you are in the UK of course...switching mode power supply model no. L11BQ, flung the box so can do any better than that im afraid
Does the MAG LT-456s require drivers
Perhaps your screen resolution is set too high. Try using a different display to set your resolution to 800x600, then attach the MAG display. Adjust from there once it is working...
Top Mag Innovision Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
