Information on the care of your product and troubleshooting is available here:
http://www.oasisleisure.ca/customer_care/SpaCare.html
Did you have a recent power outage? It is necessary to reset the temperature after a power outage.
Check the temperature setting on your hot tub; if it has defaulted do to a power outage reset to the desired temperature. If it is still set at your desired setting and is operating at 68 degrees then there is a problem that is preventing the tub from reaching the set temperature.
Some possible causes and actions are:
Pull filter (see if light comes on) / Replace filter
Knife valves not fully open / Open knife valves
Pressure switch cut of calibration / Adjust pressure switch
Faulty Pressure Switch / Replace pressure switch
Air leak, check pump suction line / Tighten pump union
Heating element corroded / Replace element
Faulty control panel / Replace panel
Find the Manual for you specifc model for more explansyion on Troubeshootig.
What is the brand name and model of your hot tub?
