Just curious, if you ever replaced your seat, and if so, which item did you get and from where? i have the same exact model 5340 and now need to have the seat replaced . Thanks for any advice you could giive me.Just curious, if you ever replaced your seat, and if so, which item did you get and from where? i have the same exact model 5340 and now need to have the seat replaced . Thanks for any advice you could giive me.
Could you tell me if you found the right seat replacement? i need to do the same thing. I have the same exact model number. Thanks in advance.Could you tell me if you found the right seat replacement? i need to do the same thing. I have the same exact model number. Thanks in advance.
If this is an old color from American Standard, you might not be able to get it anymore. Contact the manufacturer to find out how long ago they discontinued it.
Check the chain the goes between the handle and the flapper.
It should not be taught. If it is it will not permit the flapper to seat
properly and water will leak out. Adjust the chain length so the flapper is seated and there is just a little slack in the chain.
They all work pretty much the same. Feel around the top rim of the bowl near where the tank meets the bowl you should find one bolt underneath on either side of the toilet seat. Tighten the nut under there to tighten the seat.
Depending on whether "shell" is a descriptive term, or the actual color, these guys have some Elisse seats: http://www.plumbingsupply.com/toiletseats_american_standard.html
Replace the flappers, and clean around the flapper seat.
Make sure the water level is 1/2 " below the large vertical tube by either bending the float rod down or adjust the skinny silver rod on a Fluidmaster unit.
http://www.americanstandard-us.com/produ...
