Question about Microsoft Windows XP Professional Edition With Service Pack 2 for PC
I have a laptop running XP Professional. I recently upgraded my home router to a Netgear N600, but now I can't connect to the home network. The laptop finds the signal, and attempts to connect, but fails, without any error message. I had to change the network key when I replaced the router, but using the new network key on the laptop doesn't make any difference. Any ideas?
  • 6 more comments
  • Randy Hatch Mar 06, 2011
    On the new router both the SSID and the network key or passphrase was changed. The new router has WPA2 security level. Does this make any difference?
    One mistake on my part. My operating system is XP Professional w/ service pack 3 build 2600. Since this is a new router with new SSID and passphrase, wouldn't the problem be with the laptop settings?
    our other laptops can connect to the new router. my son had a similar problem with his laptop running Vista and we had to delete the WiFi settings and set up a new WiFi connection for him. thought this might be the same problem for my setup, but if not, i will reset the router to see if that makes any difference.
    Would like a 3rd opinion. I don't think the problem is with the router since our other laptops can connect to it. My laptop would connect to the old router before I upgraded the router, so why the problem now?
    Tried your solution but didn't work. One thing I noticed after I changed the wireless settings was that the new passhprase for the router is 10 characters long, but even though I typed this new passhprase into the wireless settings, only 8 characters appeared to be saved. Is there some passphrase length limit in XP?
    OK, I changed the security on the router page to WPA-PSK{TKIP}+WPA2-PSK[AES], didn't change any settings on the laptop, and now it works. ??? Hopefully our other laptops will still continue to connect without problems.
    It was a long slug, but we finally got the WiFi to work. Thanks for the help.
    This was very helpful. Thanks
  • 2,632 Answers
Welcome to Fixya. The problem with the connection is that you need to check if the Windows XP SP2 settings is the same with the router.
First you need to access the router settings page and check if the security is the same of the computer. Access the router type 192.168.1.1 then type admin for username and password for password. Select Wireless Settings. I need to verify if the Dot is on WPA2-PSK (AES).
If the settings is the same as above then we will configure the settings on your Windows XP Laptop.
- Go to Control Panel, Network Connection, Right Click on Wireless Network Connections then select Properties.
- Click on the Wireless Networks Tab on the Wireless Network Connection Properties window.
- Hightlight the SSID or Your Network Name and the click on the Properties Button.
- If your using WPA2 then change the dropdown to WPA2-PSK if the option is available.
- Data Encryption is AES same with the router, then retype the Network Key that you save on the router
- Then click Ok to close the window. Try to browse and hopefully this fix the issue.
If you have questions please let me know. Thanks for using Fixya.
Posted on Mar 06, 2011
  • 2 more comments
  • Rofel Lantican
    Rofel Lantican Mar 06, 2011
    It will depends on the Data encryption. Since you know how to change the settings in both computers and router can you change the Authentication to WPA-PSK and the Data Encryption as TKIP on both router and computer. If you will be able to connect make sure to change the settings on the other computer aswell. Windows XP might have problem or difficulty connecting to WPA2 AES encryption.
  • Rofel Lantican
    and make sure to retype the passphrase or network key since we change the encryption to WPA2 to WPA-PSK. You can use a computer that is connected wired to the router so that you still have access on it
  • Rofel Lantican
    Hatch - if everything is working fine please rate me if you can see under my name or answer you will be ask if im helpful please say Yes if i was able to help you so that i can help others. Thanks
  • Rofel Lantican
    President:
  • 3,278 Answers
Hello.
Just to be certain that your laptop is not the culprit, try to connect another laptop to your home network. If another laptop cannot connect, contact your provider to check the signal.
Hope this helps.
  • 1 more comment
  • NinaE Mar 06, 2011
    You may have done this:
    To find the key you need to log into the router. In a browser, typehttp://192.168.2.1 (depending on your network, this could be 192.168.0.1 or 192.168.1.1) in the address bar. A username and password box will appear. Try leaving them blank or key in Admin with a blank password. Look for wireless setup. Just browse through and you'll see the WEP key or passphrase. Then, change the key.
    You can get all this info if you go to Start-> (type) RUN, then (type) CMD. Then type ipconfig. Whatever your gateway number is that is the number to your router
    Since your other laptops can connect to your current router, the problem is with your laptop, as you said. Try updating your LAN card software in the laptop. Go to Device Manager, right-click your LAN card and select Update.
    Thanks for using FixYa.
    Sergeant:
  • 160 Answers
Have you changed any settings on the router ? Are you using the same SSID that you had used on your older router. Reset the router using the button at the back. Now the router will be set to defaults. Try to connect to the router in it's open state. If it connects there would seem to be some problem in the settings that you are using from there on. Change the network security to WPA 2 which should be enough for home user level security. Now enter a 11 digit pass key and make sure the ssid is not the same as it was on the older router. Look for networks on the laptop and connect to the new ssid with the 11 digit key. Now it should connect !! Oh yeah the default ip for the router is 192.168.1.1 and the Username is "admin" and password is "password". Make sure you connect the router using a wired Ethernet cable so that you donot corrupt the settings through wireless setup as the router will restart when settings are changed.
Hope this helps.
6ya staff
SOURCE:
Netgear N600 keeps disconnecting from internet
If your router isn't running firmware v 1.0.0.46 then download that from Netgear's website and upgrade the router's firmware.
Jan 28, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
Did not get a resource cd in my package. My network is not found
Go to www.netgear.com to download your resource software. You will need your model number, the N600 will not do it. Flip that router upside down or look on the sides for the actual model number or serial. Punch that in on the site to locate your download. Once you have downloaded it, run it. Hopefully that fixes your problem.
Jun 09, 2012 | NetGear N600 Wireless Dual Band Router
Cannot get 1TB WD MyBook to work on NetGear N600 Router
this link is quite illuminative
click here please
seems that drive configuration needs to be done when connected to pc first then after it's recognized, added to network router
May 21, 2012 | Western Digital Computers & Internet
Lost passkey to my Netgear N600 Double Band Router wndr 3400
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.or passphrase etc.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Apr 04, 2012 | NetGear N600 Wireless Dual Band Router
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
I recently purchased a Netgear N600 Wireless router connected to my Comcast Motorola Surfboard SB5120 modem. I have a Comcast plan of 20 Mbps but through www.speedtest.net am consistently getting 8 Mbps...
I think its the modem that you need to upgrade. Comcast is already running on DOCSIS 3.0 system. The SB5120 modem that you have is a DOCSIS 2.0 modem. You may need to have your modem replaced with a DOCSIS 3.0 modem like the Motorola SB6120.
Aug 31, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
My internet keeps goin on and off with my new netgear N600 wireless dual band router. is my home too large for this unit? any help or suggestions? thanks.jomanfitz3@aol.com
Never buy Netgear. They design product so it won't work unless you pay more for technical support. They told me the technicians during the 90 day warranty are not good enough to fix problems, so you can't get solution until warranty runs out and you have to pay extra!
Nov 26, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
Wireless connection
Hi, I am going crazy! Just moved house and took my Netgear Wireless router with me. However, even though the hard wired base unit works, my wireless laptop can't access the internet - even though a full stregnth signal is there when i browse for wireless connections. Using Vista Home Premium. Help appreciated!
Dec 29, 2007 | NetGear WGR614 Wireless Router
Microsoft Windows XP Professional Edition With Service Pack 2 for PC Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
