I guess you mean the keyboard function act as though the fn key is always being pressed? If so this is likely to be a hardware problem. Look at gently prying up the key (most keys are press fit and can be removed, lift it off as level as you can, should be relatively easy but don't force it!) once off try moving the rubber pad below the key with a small blunt instrument, keep testing other keys while doing it to see if the fn effect ever lifts of, may have got wet or something underneath the key.
To removw the Key board you need to remove three screws and after that you need to remove from top side of keyboard.
You need to remove the screws from base and latches.
I recommend you to refer the same to service center because the mechanical damage will not be covered in future.
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security Code then :- This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (Security Code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone. They should provide you with instructions on how to enter this code into the phone. Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This may be a free service. The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services.Use Google and search for "Security unlocking code” companies in your area. You can also try this WEB site :- http://www.mobileunlockguide.com/mobile-phone/ The IMEI number is unique the each mobile phone. The number is printed on the label under the battery. You can also get the IMEI number by entering this on your phone *#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
Hi. You may need to uninstall the driver for the realtek HD audio and try to reinstall it or go to the Samsung's website to download the latest audio driver for your Laptop.
Function keys on notebooks require drivers during the installation it should have seen that it was a notebook and installed the correct "keyboard driver" I suspect that it may have not. You will need to go into your settings under hardware and see what type of keyboard is installed that will solve your issue.
