Acer NSK8458AN Keyboard Logo
Posted on Mar 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Acer key board can not display the at sign above TWO key shows inverted commas instead and the hash sign above THREE shows a Pound sign? Please assist
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Mar 06, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2555124
Points
31058
Hold down the ALT(ernate) GR(aphic) key -- to the right of the SPACE BAR on your keyboard.
Press the '2' key.
Release the '2' key.
Release the ALT GR key.
Does an '@' display?
Check that you are using the "American English" keyboard mapping.
Control Panel -> Regional options.
Acer 2300 pound sign
Press and Hold the Shift Key then hit the number 3 key. The # sign is on the 3 key, but since it is above the number 3 that means you have to press and hold the shift key.
Where is the pound sign?
Totype the Euro sign in Windows, you press the alt key+0128. As for the Sterlingpound symbol, you can type it by pressing the alt key+0163. You can have a lookat this site where it lists ways to type currency symbols.
http://www.fonts.com/fontent/fontent_home.asp?nCo=AFMT&con=fyti_currency
Please note that you have to type the 4-digit code on thenumeric keypad (do not use the normal number keys) while holding down the Altkey.
1helpful
Can't get the pound sign over the number 3. I get
CANT GET £ SIGN, AND " HAS SWAPPED WITH @
1, HOLD THE SHIFT KEY DOWN
2, PRESS THE "WINDOWS LOGO" AND "ALT" BUTTONS TOGETHER ON THE LEFT HAND OF THE SPACE BAR ONLY. THE RIGHT HAND ONES WILL NOT WORK
3, YOU MAY HAVE TO USE THE MOUSE TO CLICK ON THE PAGE.
4, YOU WILL NOW HAVE THE "£" BACK & THE @ OR " IN THE CORRECT PLACE.
1helpful
Shift/hash gets the UK pound sign and shift/at gets double inverted commas
Go to the control panel > regional and language settings and make sure all are set to both US-English.
3helpful
I just replaced the batteries in my HP 12C calculator and when I turned it back on the display looks like this 0,000. How do I get the display to show decimals instead of a comma?
Here is what the manual for the HP 12C Platimum financial calculator says on page 17 of 275
Digit Separators
As a number is keyed in, each group of three digits to the left of the decimal point is automatically separated in the display. When the calculator is first turned on after coming from the factory — or after Continuous Memory is reset — the decimal point in displayed numbers is a dot, and the separator between each group of three digits is a comma. If you wish, you can set the calculator to display a comma for the decimal point and a dot for the three-digit separator. To do so,
turn the calculator off, then press and hold down the [ . ] key while you press [ON] Doing so again sets the calculator to use the original digit separators in the display.
Hope it helps.
5helpful
2answers
Toshiba at the rate and invertd comma keys are interchanged
Dead easy, go to the Control Panelselect region and language settings.
On opening you will get a pop up with 3 tabs
!st tab change region to UK
2nd tab click details and change all options to UK
That's it done.
2answers
Can not use a pound sign on my laptop
THIS MAYBE A KEYBOARD PROBLEM OR THE KEY BOARD SOFTWARE NEED TO BE RESET OR RE INSTALLED AND THAT MEAN A TOTAL INSTALL AS FIRST TIME YOU GOT YOUR MACHINE
1helpful
Two keyboard keys seem to have been transposed
Yes when going through the setting up procedure for your new computer you should have installed the British keyboard instead of the US one.
Doing the above will correct your problem.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
