Sigma Telephoto 105mm f/2.8 EX Macro Autofocus Lens for Nikon AF-D Logo
Posted on Mar 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I just brought my sigma macro 105mm lens and Im having trouble getting it to work probably on my nikon d90, they only way I can get it to work is turn the aperture on the lens to f32 I cant change it to any other aperture, and on the camera it pops uo F33 error and I cant take a photo it dosnt matter what setting im in manual auto shutter piroity etc please help, I didnt recieve a manual with my lens Im quite stuck, and when I have the lens turned to f32 and working i cant seem to zoom in very far, is it possible that something is wrong with my lens and should I take it back to the shop I brought it from, thanks for your help From Haley
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Sigma Master 102,366 Answers
  • Posted on Mar 06, 2011
Sigma Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442950
Points
622693
Turn the aperture ring to f/32 and leave it there. After that, forget the lens has an aperture ring at all. You can let the camera control the aperture in any mode except the M and A modes. In the M and A modes, you control the aperture by turning the command dial on the front of the camera, the same way you control the aperture on a lens without an aperture ring.
I would like an instruction manual please.
The user manuals coming with lenses most of the time have little information about how to use them. The lens will have a MF and AF and perhaps a VR switch. If you want to learn more about macro photography, check this site from Ken Rockwell, where he is explaining how to do so with a Nikon camera.
Be aware the macro lenses are designed to focus close to the camera and will have the sharpest pictures close to the camera. I would not say you can't use a micro as a tele, but the results with a normal 105 could be better.
Still I think you have a great lens with your Sigma.
How to Shoot Macro
1helpful
Sigma lens manuals
Chuck, sorry for the late response. Last days I had to work through several hundred anonymous questions. Most irrelevant and not complete, so I could not answer most of them, but I had to read them all.
Sigma, does not have a service, where you can download a manual. But the manuals from Nikon, most of the time don't tell anything about how to use the lens.
I found a page with all specs. The link is down here.
I have to guess why you did put the question here in the first place. I think because you have a Nikon camera without a focus motor. Like a D3x00 or the D5x00 or a D40 or D60. (for the x you can add 0 1 2 or 3)
If you have one of these camera's the lens can't be used with auto focus You only can use the lens in manual focus. Most other camera's from Nikon, like D80 D90 D7000 D300 and more expensive, all do have a focus motor and can work with this lens in full automatic focus mode.
50mm F2 8 EX DG Macro
D5100 won't power on with Sigma macro lens atttached
This is not a solution but the same kind of problem.
I just bought a Nikon D5100 and found that my Sigma 105mm macro has a problem. The camera will not power up, but if I turn it on, untwist the lens and then twist it back in, the camera powers up. If I leave it for a few seconds, it powers down again. Provided I keep taking photos, it works, but this is not acceptable because it can take several seconds to get a focus on a close-up, and by time I get the focus, the camera powers down again.
I never had any problems with this lens on my Nikon D80. I also use several lenses, all of which work well with both cameras. It's only the Sigma that has the problem. And I did clean the contacts with a proper contact cleaning solution and a swab, but still no joy. My lenses are made by Tamron, Pro Optic, Nikon and Sigma, and the only problem lens is the Sigma.
According to the manual for my Sigma 105mm f2.8 EX DG Macro lens with my Nikon D90, when using P or Sutter priority auto mode the diaphragm control ring needs to be set to the smallest aperture(f32) and...
In all modes the aperture ring on the lens should be locked at the smallest aperture. In the M and A modes you control the aperture by turning the command dial on the front of the camera. In P and S modes you control the aperture indirectly by turning the command dial on the back of the camera.
2helpful
Hello sir, Well it has been raining for a few days here and my cam has been exposedto bit of moisture as i indulged in a bit of early morning shoots. The thing is i get absolutely fantastic images with my...
It could be condensation inside the lens. It could be a problem with the focusing. It could be other mechanical/optical problems with the Sigma lens. If the problem persists after the lens has thoroughly dried out, take it in to a reputable camera shop and have it checked out by a qualified technician.
Sigma User Manual for 105mm f2.8 Macro
Well you can please follow the link below to get your manual -
http://www.dphotojournal.com/sigma-105mm-f28-ex-dg-macro-reviews-sample-photos/
(click on the manual tab and then click on - Download Sigma 105mm f/2.8 EX DG Macro User Manual (PDF – 67kb), thats it)
Good Luck!!
Thanks for using FixYa!!
1helpful
WILL THIS MODEL JELL WELL WITH THE NIKON 50mm LENSES (NORMAL) & OTHER BRANDS OF 50mm LENSES (NORMAL) THAT IS WITH NIKON D90 DSLR
The Nikon D90 works well with the Nikon AF 50mm lenses and most other brand Nikon fit AF lenses. If they are not AF you will lose autofocus and metering.
Do you know that on the D90 the lens becomes a 75mm but the aperture stays the same, so for instance the 50mm f/1.8 is a 75mm f/1.8.
My nikon d60 does not recognize my sigma 105mm lens
Hi I had a similar problem with a 50mm prime and I fixed it by locking the aperture ring on the lens in place.
Top Sigma Cameras Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sigma Camera Expert? Answer questions, earn points and help others
