The printer has a working mode and a standby mode. It could be going into the standby mode. Pressing the power button once, or sending it a print job will usually take it out of standby mode.
Most HP All in Ones will give a problem message on the screen. Your printer may have a more involved problem and you should go to the (hp.com) printers support page at HP. When you get the support page for that printer, type the error code in the search box.
If you are plugging it into the RJ45 Network connector (without a network) you may need to use the printer setup settings to tell it what type of connection to use ( USB or Network).
If the printer is connected to your telephone line and you are using a DSL internet connection you need to put a DSL filter on the telephone line going to the printer. The printer may be picking up DSL internet signals. Again the printer setup utility will ask you what type of connection you are using.
Have you tried reinstalling the software for your printer? make sure you uninstall it first before reinstalling it.
