Microphone not being recognized
posted by n00ber on Jul 30, 2008
i was trying to get in-game chat to work but my microphone is not being recognized. after following all tech instructions and seeing if drivers needed to be updated (they were fine), i am still having no luck. the microphone plugs into the back (non-usb type) and requires no software. any ideas are much appreciated!
Comment posted on Jul 31, 2008
yes, i was sure to check, double-check, then triple-check that it was plugged in correctly and the microphone itself is not set to "mute". i am legendary for making those types of mistakes.... :)
Comment posted on Aug 02, 2008
there is a game "repair" function, which i did run, but everything came up clean. i ran through every possible in-game problem with blizz tech support, but everything was set up properly. tech support had me navigate to my sound recorder (windows menu, all programs-accessories-entertainment-sound recorder) and they had me attempt to make a short recording using the microphone. it failed to make a recording there, which apparently indicates that my computer is not recognizing that my microphone even exists.i'm pretty comfortable with that assessment...i just need to figure out *what* is going wrong.
Comment posted on Aug 13, 2008
yes, it is plugged into the appropriate hole, and just for giggles i did switch it around to make sure nothing was backwards. didn't work that way either (which is good i guess!)
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 30, 2008
Helpful (85)
colliewob
Rank:Wiz Wiz
Rating: 84%, 416 votes
is it in correct hole the one with a picture of a mic on it
are there any in game ways to set to default reboot and the try to set up for your game
Rating Locked! (?) n00ber has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on microphone not being recognized:
I don't want to Accept this solution
Can you Help with these Sound Cards problems?
Sound Cards
viaaudio.sys file
Sound Cards
i have a hp dx 2280 audio driver for win 2003 os
Sound Cards
Ok so I downloaded VoipCheap and there are like 5 steps to...
Philips Dynamic Edge 4.1 PSC604 Sound Card
register key Dynamic Edge?
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Top Repair Providers for
Computers & Laptops
(888) 430-9744
Computer Repair Over The...
OverNetUSA
(412) 715-4340
We will fix all d-link or linklsys wireless...
ATCS Incorporated
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
X
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
