Saeco Royal Professional Espresso Machine Logo
Posted on Mar 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The machine will not work. The screen say Ventilate and will nothing will work. How do I get the word Ventilate off.
Ginko
Level 3:
  • Saeco Master 19,396 Answers
  • Posted on Mar 28, 2011
Ginko
Saeco Master
Level 3:
Answers
19396
Questions
25
Helped
8077601
Points
55462
3answers
How do I make ventilate message go away
  • Check to make sure there's nothing inside your flow meter.
  • Check the flow meter wire connection at the board (cpu/pcb).
Ventilate sign is showing and nothing works
Open the steam valve when the hot water words appear above the ventilate
1helpful
VENTILATE appeared on the screen. machine stoped working?
Try open for steam, it could be that there`s an airbubble inside the fluidsystem. Or maybe check the manual if ypu need to empty the system after using the steam, I know some older models has to be ventilated after the steamprocess.
2helpful
New Royal espresso machine
Run hot water cycle to ventilate machine.
6helpful
3answers
My coffee machine says "ventilate"
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
V entilate?
the machine come with a little pump put water in the pump and insert the pump inthe water hole and press the water in the machine try to ventilate fill the water tank cheers
29helpful
6answers
Keep reading "ventilate" on the screen
Running hot water button a few times worked for us
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
