Hi!
For you to install a theme to your handset, first, you need to download an installer to your computer, try
www.mobile9.com, after downloading the file, locate it first, connect your cellphone using USB connector, then select MASS STORAGE on your handset, now, transfer the file to the cellphone's drive or memory card. after that, safely remove the handset from the computer, locate the file from your cellphone by going to the file manager and then run it.. if it shows error, try to download another one. by the way, the OS of your cellphone is SYMBIAN S60 ver.9, so be carefull in downloading a file it should be in .SIS format. THAT's IT!
Please don't forget to click on 4 THumbs UP at the TOp!! THANKS!
