Reconnect the connector J18 of the yellow drum motor and the connector J120 on the DC controller PCA. Perform the drum-motors component test in the DIAGNOSTICS menu. If the message persists, replace the yellow drum motor.
Error 20 is an error code in Xerox laser printers which indicates interior hardware damage.
This printer problem usually occurs after the installation of new parts or supplies. It means the installation was not done correctly or a part is already worn out and needs replacing.
Here's what to do when Error 20 Code appears on Xerox Phaser 6500. When this error code appears, one of the first things to check is the toner level.
It might be too low to print with the consistency that it requires replacement. If you have replaced the toner cartridge and the error persists, reinstall the cartridge.
Turn off the printer wait for a few seconds before turning it back on.
Avail prompt online help by experts just at dialing Xerox Printer Support Phone Number +1 888 597 3962 which is available 24×7 hours. We are independent customer service providers, and having a team of experienced and dedicated tech support technicians, who are always ready for assistance. Our proficient technicians have provided the most appropriate solution and tremendous guidance e to customer for resolving their Epson Printer technical issues. Hence, call us the at toll-free number and get the extensive support, easy guidance and 100% guaranteed solutions with our professional help to resolve Epson printer issues within a defined timeline.
I had the same problem and it was the pick-up roller that was at fault. You can buy a new one for less than 20GBP or do what I did. Take the old one out and reverse the rubber. There are plenty of online tutorials on how to change the pick-up roller - the first one you remove. It's a two minute job. Reversing the rubber is easy. Just prize the inner clip out of the roller and put the rubber back on with the shiny side out. It worked first time and no more print errors. HP CP2025 How to Replace the Pick up Rollers and Separation Pad
Remove the toner and shake it a little. You can put the toner back in the printer. If this does not fix the issue, Turn off the printer, unplug the power cable from wall outlet. Wait for 1 hour and plug the power cable and power on the printer
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
