JVC Everio GZ-MG130 Camcorder Logo
Posted on Mar 05, 2011
Display works perfect , but when i try to rec. something i cant see nothing on the display .
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 06, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
157
Points
My videos and pictures are not showing in my laptop and also in pc.
2answers
The rec nav radio screen has grey black and white lines and nothing else
If you ever found an answer to your problem I would really appreciate the help. Mine just started doing the same thing today. The screen has lines on it but the sound works fine. 2005 Jeep Grand Cherokee Limited. Thanks
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
35helpful
2answers
How to convert polar to rectangular form
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
Hope it helps
2answers
Problem when Trying to record
If you are trying to record to a tape and the display shows "Protection", you must slide the protection tab at the top of the tape to the "Rec" position.
Vb 6.0 ado connection without ado control moving next record
I see 2 problems with your code.
1) Each time you call cmdnext_Click, you're reopening the database. Each time you do that, you start at the beginning of the file. You need to have the database opened once, somewhere else in your program. Be sure that the record set is visible from this sub.
2) In order to use the "Next" function, you need a loop like this
'test for no records
IF REC.BOF and REC.EOF then
msgbox "No Records Found"
exit sub
end if
IF NOT REC.EOF then
REC.MoveNext
(display your fields)
END IF
Again, this will only work if your database is opened outside of the cmdNext_Click routine.
No sound
Make sure speakers are hooked to proper connectors. Also check speaker switch "A"/ "B"/ "A+B" is positioned to correct speakers.
Also make sure mute switch is off
My first gen nano, displays apple logo, nothing else
something has bin tuched inside and fused it maby need a new ipod try taking it bk to apple store p.s try getin a cover next time then you wont need new screens
Cant record
Hello, please check this link: http://www.imaging-resource.com/badccds.html According to this you may have the camcorder repaired free of charge. Best regards, Arpi
LCD Monitor is not working
Perhaps the back light tube has blown. Not a repair job if it has- replace the camera- check Canon website
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
