Proscan 42LA30H 42 in. LCD Television Logo
Posted on Mar 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture "flickers" from dark to a lighter
Vincent G
Level 3:
  • Master 2,363 Answers
  • Posted on Mar 05, 2011
Vincent G
Master
Level 3:
Answers
2363
Questions
Helped
1032981
Points
5917
This is a board level fix.
The part is about $10. + time to solder on the part
Capacitor C809 is failing.
390mfd @250V
My Nava 13 inch tv/dvd the screen is constantly flickering. It worked great until i moved recently. Why is my screen constantly flickering - what can I do to make it stop?
It could be interference from something, so make sure there are no wires near the aerial lead.
Give it a sharp tap on the side or top.
Buy a new 46 inch Samsung!
This is an unknown make!
https://www.google.com/search?q=Nava+13+inch+tv%2Fdvd+the+screen+is+constantly+flickering
My screen goes dark. I can make out the picture but the left side is almost black, and the rest of it looks dark and/or flickers black.
I was told to replace the master and slave inverters as the capaciters were popped, still didnt fix the problem, have you had any luck???
3helpful
Noticable flickering when viewing dark images.
Hello, I too experience this exact same problem. In my opinion, any television under 2 grand is probably going to have some slight imperfection as this; I have tried a few different ones myself. To some, it would appear to only be a minor annoyance, but to those who truly can distinguish a good quality picture between a bad one, or to those people, such as myself, who would find something like this to be unacceptable, this is a disheartening situation.
My friend, I have tried many different settings to see which ones might resolve this issue with the blacks in the picture, or at least reduce it to a barely noticeable level and I have found that when I select the CUSTOM picture mode, reduce the contrast to about 60, turn up the brightness to 62, turn OFF blur reduction,x/v/ color on, CATS on, MPEG NR ON, turn Dark level to LIGHT(this is important) add a little bit of extra color for ex. 52, and sharpness to 75, that this produces a pleasing to the eye performance when watching blu ray movies and dvd's. The flickering is reduced to almost nothing, and the picture quality actually appears sharper and more ethereal in certain ways.
The downside to this is that you are lacking some true depth in the picture's darks, but after your eyes adjust and you are watching a good quality movie, you will notice that there still sort of is enough darks there to compensate. Further fine tuning may produce even better results, jsut have to keep playing around with it. But I am now convinced after hearing somebody come forward with the same exact problem i'm having on the same tv, that it is not a defect but just an imperfection that you sometimes have to deal with when you don't spend like 5 grand on a tv. Good luck and happy viewing!
1helpful
No picture screen remains black some flickering
hi
what you are experiencing is that your screen bulb is burnt.the screen bulb is what lights up your screen, its just like a fluorescent tube,when it is burnt it flickers for a while and it later goes off.. the only solution is to change the screen bulb as soon as you can
goodluck with that!
3helpful
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
2helpful
The tv works however the picture dissapears/ flickers off but comes right back immediately...happens constantly
Picture tube ( CRT ) is defective = re-juvenation may help for
a temporary fix...................................T.
Flickering - Toshiba 62HMX84
it could be as simple as the tv feeding back on itself in a dark room.
it is adjusting the light level because of what it sees ambient in the room.
turn on a light near the tv and see if it stays constant now.
Repair of digital camera
If you see all black in the viewfinder something bad has happened to the lens. It could be stuck, tilted, etc.
It will need to be taken apart and serviced by a trained technician.
4answers
If you go to nikons home page you can search and find that they are willing to fix this free of charge.
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
