Since last night my DCS12w is not draining water even though it finishes its cleaning cycle.
I have been told the pump may be jammed with grease and needs cleaning. I tried running the machine with extremely hot water in a hope of dissolving or moving the blockage but this didn't help
I'm not a complete novice when it comes to mechanical stuff but I can't find a service manual anywhere to tell me how to get at the pump to check if it is jammed or needs a new one.
Can anyone tell me where the pump is located and how I get at it?
Any help would be greatly appreciated.
SOURCE: too long for a cycle
There are a lot of reasons could cause this issue. Could you provide us more details (if you have) which cycle's stage "takes" this time (filling water, washing process,draining etc... ) You answer will allow us to direct you the solution. Good luck !
SOURCE: Cycle completes but doesn't clean!
heater element may not be working,not heating water,good luck
SOURCE: Drain pump removal on Zanussi FJR1254 Washing Machine
not easy.suggest you disconnect pump and power up independently as an easy way to check if it runs
easiest way to remove pump - and its awkward - is to undo the 3 screws holding the pump to its housing
SOURCE: zanussi zdt6053 will not fill with water
how i can operate the zanussi zdt6053 because i lost the manual can you support me please
SOURCE: ZDT5052 flashes quickwash light
I had the same problem. After cleaning hose between unit which measures water level (located below, near right leg) and sink everithing works fine.
