Good afternoon,
Equity has the instructions on their support page, but no actual instruction sheet is available:
http://www.equitybylacrosse.com/i-need-instruction-manual-my-model-40001-clock
Hope this helps! Please rate this solution.
Thanks,
~PCF
Testimonial: "Thank you for your help! I was dreading having to return the clock if I couldn't set the time or year. BTW - It's a clock; not a vacuum."
Travel alarm clocks can have varying
instructions, depending on the type of clock you are using. Here are
some tips for use that will apply to any alarm clock.
The Sio/Scan Atomic clocks should automatically set the time and date.
Place the clock in a window facing towards Colorado and give it 24 hrs to update
If that fails here's the web site for them:
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
And this conclude's Search Marketing Guru's public service announcement. :) We'll be back with relevant online marketing posts with our next posting!
