Very simple - call a Plumber. He will fix your plumbing problem, and any foreseen potential problems related to your water leak. He may also suggest replacing your 6 year old water heater. Of course ..... for a professional cost.
However, depending on your time, skills, proper tools, patience and luck, it's easy enough to perform yourself:
1. Switch off the water heater Breakers (220v) in your service panel.
2. Turn off the water supply to the water heater.
3. Attach a water hose to the drain faucet. ( a good time to flush sediment -calcium deposits)
4. Open a hot water faucet to vent (above the level of the water heater drain - kitchen sink)
5. Remove the suspected leak components. (a union connection is a good place to start)
6. Install New pipes -3 wrap all male threaded ends with teflon Tap. Tighten securely - using 2 wrenches.
NOTE: Before refilling - you can turn on the water heater supply valve for a few minutes, to flush out any lingering calcium debris.
7. Shut off drain valve - remove hose. Shut off venting hot water faucet.
8. Turn on water supply valve to fill water heater.
9. Open a hot water faucet to relieve air pressure while filling - preferably the bath tub faucet, it doesn't have a screen that might clog.
10. When water flows without air - shut off tub faucet.
11. Look for leaks.
12. Switch the water heater Breakers on.
Note: 50 gallons should take an hour or more to heat up. Turn on a hot water valve momentarily within this heat up time to relieve thermal expansion. ( the PT valve on your water heater will perform this task if pressures/temperature exceed new water heater tolerances - it's just a precaution to introduce these fluctuating pressures on your fragile 6 year old unit)
These are just basic instructions - assuming you fill in the common sense and work safe steps.
Good Luck - The Skill will only come after trying.
