First things... you have checked the inler filter andthe gas pressure, but have you checked and cleaned the thermistor(s)??? Also the flame sensor... clean that with a soft cloth...
Next turn down the temp with th dip switches that should tell you if it is the high limit...
Has the unit been cleaned with vinegar or CLR lately or ever??? there maybe buildup internally in the unit...
Is the flame a nice blue color or is it yellow???
Does it go out just before the unit cuts out???
Do the flames lift from the burner???
These are all things that I would be checking if I was coming to your home to check this unit...
Comment back with any other questions or comments...
heatman101
If this is that new of an install, then I would get the installer to come out and check the unit out.
My focus would be on the sensors... it would seem as though one of the sensors is bad... but also do check the flame out and make sure the gas pressures are correct. A regulator may need to be installed.
Brand new unit. worked for a week, then error code. dip switches at factory setting 122 degrees.
Was none of the solutions held forth. Was knowing the right combination of buttons to push in which sequence. Thank you for your efforts.
