This issues is related to usb drivers for your GPS. Most times you can go to your GPS manufacturer site and just search for usb drivers for your gps device tha are specific to your Operating System. Once downloaded on your pc, install the driver and this should allow you to see your GPS as another drive in MYCOMPUTER folder. Hope this helps.
Testimonial: "Tanks !!"
Insert the memory card into the memory card slot on Garmin
Nuvi 250 GPS device. The memory card slot is located on the left side of the
device. Push the card in until it clicks. (If you inserted a memory card that
already has pre-installed maps and files, there is no further action required.
The device will access the new maps based on the address you enter.)
Connect the Garmin GPS to the computer using the USB cable.
The mini-USB connector will need to be inserted into the rear of the Nuvi 250;
the larger end is inserted into the computer's USB port.
Locate the computer file that you want to download to the Garmin
memory card. The Nuvi 250 is capable of reading JPEG formatted images and GPX
formatted Waypoints and other mapping-related files. Right-click on it. Select
"Copy."
Select the "Computer" folder from the computer's
desktop Start menu. Double-click on the "Removable Disk" drive that
represents the Garmin Nuvi.
Right-click in an empty space within the drive and select
"Paste." The files have now downloaded to the memory card and will be
accessible through the Nuvi 250 menu options.
Good Luck, and do rate the solution if got help
