HP DeskJet 3650 InkJet Printer Logo
Anonymous Posted on Mar 05, 2011
The printer is presently giving me copies of past requests....it is printing things that was asked to do weeks ago ....hence when I now ask it to print a new Briar Curling schedule for example,it will print me copies of the passed and not the Briar schedule. Iam using alot of patience,ink,and paper. Please help.
Anonymous
Level 2:
  • Expert 157 Answers
  • Posted on Mar 05, 2011
Anonymous
Expert
Level 2:
Answers
157
Questions
0
Helped
55103
Points
442
On the taskbar see a printer icon on the right-bottom corner. Double-click to open the printer icon (or alternatively go to Start > Settings > Printers and faxes > Double-click the right printer). Then delete all pending print tasks from the list.
  • Anonymous Mar 07, 2011
    P.S. If this helped you to solve the problem (or at least brought some clarification) - rate this solution with 4 thumbs up! But before you would give a negative rating - post a comment, so I could improve my solution to satisfy your needs. Thank you!
My xerox 6015 will print documents that I have previously printed even tho I am not requesting it to be printed. Nothing is in the print queue to cancel. what is wrong with it?
I assuming you mean you get 2 prints when you only asked for one. Looks like the driver default settings are set to 2 copies.
If you can use the copy facility and print one copy that sort of eliminates the printer. The problem must be further up stream towards the computer sending the print.
You also. If he like to remove the print driver and reinstall it, the default must always be set to 1 copy.
4answers
HP 4300 officejet fax mode to print mode
Hello etilton
Are you trying to print from a pc or do a copy?
Button 11 Fax: Places the HP All-in-One in fax mode and presents the Fax Menu. Press Fax
repeatedly to scroll through the options in the Fax Menu.
Button 12 Scan: Places the HP All-in-One in scan mode and presents the Scan To menu for
selecting a scan destination.
Button 13 Copy: Places the HP All-in-One in copy mode and presents the Copy Menu.
Press Copy repeatedly to scroll through the options in the Copy Menu.
heres the rest of the manual pdf reader required
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
If this solution was any help at all please press accept or ask more questions with the other button.
And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
On kodak esp 1.2 is there a head cleaning switch, as printer worked 3 weeks ago asked for ink, which has been done but now saying no ink
check your print head it is stopeed up, remove it and clean with water just the jets, or use qtips, plain water no chemicals, Matt
ID Copy asks me to present front side and then back side. But it prints one side only.
You have to flip your card over, scanners only scan one side of things and that what is facing down
If you need further help, reach me via phone at https://www.6ya.com/expert/william_ecd28f5eabcb9eb6
Will not print photo. Asks for card. Need to print from computer, not from photo card. It has worked in the past.
You just have to send the print request from the computer, if you press the photo button on the printer it will always tell you to insert the card. It knows how to print when it's sent a print request.
HP Photosmart C6350 prints more copies then asked for
How do I turn off the ink level system on my HP all in one C6350 printer?
Bizhub 250 slow to print files
When you ask to print the page are you asking for more the one copy? If you are there is a collate check button next to the requested sets box, in the print dialog box. Make sure its not check. Collating the print means your PC sends a copy of the file for each requested copy. IE: you print one page and ask for six copies, your PC sends the file six times, one copy of the file for each print requested.
Also because your printing from a windows application IE: Excel you should be using the PCL print driver as apposed to a PostScript print driver. The time it takes to convert the file into PostScript for the printer to process it is time consuming.
I have a Lemark Printer series 3500-4500 have aproblem with printing Pictures what can I do
my printer will not copy what i want to copy . i have tried to copy something new and it keeps going back to what i copied a week or two ago . iv'e canceled and tried every thing i know . very disgusting. help .
HP2430n prints out 2 copies when I ask for one
go to the properties section of the printer, then go to Device settings make sure # of copies is set to 1
Then check the settings in the printer Menu.
Dell 942 all in one printer reinstalls itself
Not sure what your asking here. Please restate your problem and give all the details. The more the better so we may understand whats going on.
k24674
Grand Canyon Tech
Grand Canyon Tech
