Microsoft Xbox 360 Console Logo
Posted on Mar 05, 2011
My xbox 360 will no longer work i plugged it in yesterday and the green power light in the middle came on but i got none of the flashing green circling lights that appear just before it gets to the dashboard any help or advice would be greatly appreciated thankyou
Anonymous
Level 1:
  • Contributor 326 Answers
  • Posted on Mar 05, 2011
Anonymous
Contributor
Level 1:
Answers
326
Questions
0
Helped
82741
Points
83
The flashing lights on the outside of the green power button are the status lights for any connected controllers.
Just turn on one of your wireless controllers and the green status lights should come on.
If you turn on a controller and it doesn't automatically connect, press the connect button the top of the controller and front of the Xbox at the same time. This should connect the controller.
My XBOX 360 will not turn on. The power bar has a green light but pressing the eject button or power button on the console will not turn it on. We have tried plugging it in to a different outlet but that...
Hi christoph52893,
If the Xbox 360 power supply light is green, this means the Xbox 360 power supply is ok and it is an issue with the console itself. You will need to contact Xbox 360 customer support to service your console. However, if you have a flashing orange or yellow light, it means that your console is fine but instead there is something wrong with your power supply. It indicates that it's not getting enough power.
Hope it helps.
Thank you for using FixYa.
2helpful
Trying to install kinect to xbox 360 get error message C00000C2
Welcome to Fixya!
Solution 1: Update your console software
  1. Insert a Kinect game disc.
  2. Start the game from the Xbox Dashboard.
  3. If your console software needs updating, you will see the following message:
    Update Required: An update has been found, to apply this update you must restart your console.
  4. Select Yes, Restart to install the update
Solution 2: Check the cables Xbox 360 S console
  1. Turn off the console.
  2. Unplug the sensor from the console, and then plug the sensor cable into the AUX port on the back of the console.
    Important Remove the power/USB adapter cable if your Kinect sensor came with one.
  3. Turn on the console.
Original Xbox 360 console
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
    The light located near the middle of the split cable should be green.
    No green light? Try plugging the cable into another outlet to make sure that the cable is working properly. If you still do not see a green light, your cable might need to be replaced. Contact
    Xbox Support.
  4. Turn on the console.
?Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
10helpful
2answers
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
1helpful
Tree lights in red
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
1helpful
360 dance pad not working on xbox
try plugging your usb connector into the usb port located in the back of your xbox 360 next to the power cable coneccion
1helpful
Flashing Green Light
your xbox might be downloading a game that you ask to download or some other type of media. to chick turn it on and go to active downloads and see.
Three red lights
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE: The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION: If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
2answers
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
