Canon PowerShot A95 Digital Camera Logo
Posted on Jul 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E18 on Canon Powershot A95
Hi, My trusty powershot has lost it's mojo. Actually it keeps powering down with a strange whirring sound then E18 comes up in a blank viewfinder. Do I need to get it serviced and where?
Thanks very much.
Virginia
Lee
Level 3:
  • Master 393 Answers
  • Posted on Apr 25, 2010
Lee
Master
Level 3:
Answers
393
Questions
0
Helped
106201
Points
1319
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
take a look at e18error.com website for more info
2helpful
When i turn my cameraon the lens opens ans then shuts automatically with an e18 message on the screen and then makes a strange whirring noise
Go to this website for help. This is a common problem and there is an actual website devoted to this very problem. www.e18error.com
1helpful
When Canon Powershot A95 turned on, lens opens, CHEEPS, then closes, followed by 6 sequences of 'clicking chatter' and further CHEEPS. Message 'E18' appears in lower left of CCD.
It is Fixable around $100 - $150.
http://www.e18error.com/
On the above link, you would see a Lawsuit against Canon for the same.
This Error usually Requires a Replacement of Lens which is not cost effective relative to the cost of the Camera.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
My Cannon PowerShot A95 keeps coming up with E18 when I turn it on. What does this mean?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
1helpful
E18 error w/sound effects!
Canon A95 Cannot be switched off
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
8helpful
My A95 Powershot pictures all look pink
Its known problem of ccd imager in Canon A95 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
Thanks.
Canon powershot a95
I have a probnlem With Canon A95 camera, there is a e18 eror on dysplay.
E 18 problem
I have the same issue "E18" on my powershot A95 and i don't know how i can solve it. Sorry. Loic
2helpful
2answers
Whirring sound after start then black screen with E18 in bottom corner
this is very easy to fix- switch your camera on, grab then lens around the edges, and carefully give it a firm twist. It should click and turn on.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
