Hardware & Accessories Logo
Posted on Mar 05, 2011
I need your help, my mom has a timer by Taylor,I cannot find the paper work on it. can you please help me it has a START/STOP button , a M button and a S button, I don't know how to work it, know nothing about it but need it for timing things I am cooking for her, Please can you Help me. Thank you!!!
Anonymous
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Mar 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
9567
Points
91
Love those Taylor Timers! From your description, I believe your mom most likely has the Taylor 5806 (picture below / product website: http://www.taylorusa.com/kitchen/timers/digital-timer.html).
If so, the small instruction sheet that comes with this upon purchase can be found here:
http://www.taylorusa.com/media/IBs/5806_ib.pdf
I hope this answer your question, and if so, please be so kind to give this a thumbs up! Have a good one!
How do i set the clock on a taylor 5846 digital timer
Press the Mode button until you are on the clock.
Then press and hold the Start/Stop button for 3 seconds.
There should be a beep and the digits will begin to flash.
Press the Min button to increase the Hours and press the Sec button to increase the minutes.
When you have the time set, press the Start/Stop button to finalize the setting.
3helpful
How do I reset the clock on a Taylor 5846-9 kitchen timer?
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
To set timer:
To time activities:
4helpful
How to set the clock on a taylor 5846 Slim Digital Timer
11helpful
How do I reset the clock on a Taylor timer 5891-21?
1. Press and hold the "Clock/Timer" button until you hear a beep and the time starts to flash.
2. Adjust the time using the "Hour" and "Minute" buttons. Note the clock includes AM/PM.
3. Tap the "Clock/Timer" button to restart the clock.
2answers
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
The supply of electricity was interrupted now the timer will not stop flashing and I need help to get the oven on please Its a hotpoint BS 22
Hi.
there are many variations of timers but if you select oven to on and press the timer buttons in turn one of them will reset the timer back to manual mode. It should click and the display should stop flashing and the oven should start.
If that fails then press two buttons in turn. if still no sucess then I am affraid it could be a timer failure.
If you need any further assistance please email me your details to [email protected]
Hope this helps
Aardvark Repairs
4helpful
Reset timer between batches of cookies
click the Hr/+ and the Min/- keys at the same time...the timer will reset.
9helpful
2answers
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 • Watches
Top Taylor Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Taylor Hardware and Accessory Expert? Answer questions, earn points and help others
