SOURCE: Steam out from engine pipes/hose
It looks like from the picture you have a leaking radiator hose/connection. Remove, clean, inspect, replace hose if needed, or tighten connection.
SOURCE: I have a Casio Exilim EX-Z75 digital camera and
Try replacing the battery, it seems a battery issue
SOURCE: Flashing LED on Samsung SBC-N1 Charger
Not so much a problem, more curiosity and the lack of a manual to explain the flashing LED. There are 2 batteries with a LED each. I swapped the 2 batteries over to see if the flashing LED followed the battery and it worked fine with the batteries swapped! They even charged normally. I still have no idea why the LED was flashing?
SOURCE: lost charger for camera battery
not sure if this does it for you, but there are USB battery chargers on Ebay for this camera. I've got the same problem and that's all I've found - so far.
SOURCE: i just got a hp PB360t digital camera and lithium
This recharger must be for several types of batteries, which is why it this battery seems not to fit in it. I, too, was perplexed until I looked at the icons on the recharger and the icons on the battery. When looking at the recharger with the LED on the left, place the battery in the top right corner. It just fits and will fall out if you nudge it just a bit. HTH.
