SOURCE: Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
SOURCE: F&P Active Smart E521TRE Removing freezer back panel
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
SOURCE: ice building in freezer and water leaking in the fridge section
I will say that you may have to call someone in, but it is most likely the thermostat for the freezer, when the freezer reaches setpoint, that stat will kick the compressor off, but it sounds like yours is running until it the coils freeze, which brings another problem in hand is a dirty coil. Those two are your best bet. Best of luck!!
SOURCE: E521T fisher & paykels fridge is freezing everything
trn your thermostat right down see if that helps
