How to use Braun ThermoScan 1. Always make sure a new, clean lens filter is in place to help ensure an accurate reading. The thermometer will not function without a lens filter attached (see Changing the lens filter). 2. Press the /mem button. The LCD (liquid crystal display) is activated, showing all segments. When the ready symbol is displayed the thermometer is ready for use. 6 To help ensure an accurate temperature reading, use the following technique: If you are right handed, hold the thermometer in the right hand and take the temperature in the right ear. If you are left handed, hold it in the left hand and use the left ear. 3. Perform an ear tug to straighten the ear canal. This gives the thermometer a clear view of the eardrum. Children under 1 year: Pull the ear straight back. Children aged 1 year to adult: Pull the ear up and back. An ear tug is best performed by using your free hand to grasp the outer edge of the top half of the ear. To take your own temperature, wrap your free hand around the back of your head and grab your ear from behind. 4. While tugging the ear, fit the probe snugly into the ear canal as far as possible and press the activation button. Release it when you hear a beep. This is the Temp Beep that confirms the end of measurement. 5. Remove the thermometer from the ear canal. The LCD displays the temperature measured. 6. Replace the lens filter after each measurement: press the ejector button and put on a new, clean lens filter. 7. A new measurement can be taken as long as the ready symbol is shown. If no button is pressed within 2 minutes, the thermometer will turn off automatically. 7 Note: In the following situations, it is recommended that you take three temperatures in the same ear. If they differ, use the highest reading. · Infants in the first 90 days of life. · Children under three years of age who have a condition such as a compromised immune system and for whom the presence or absence of fever is critical. · When you are first learning to use the ear thermometer until you are comfortable with the technique and are obtaining consistent readings. Important: As with any type of thermometer, slight temperature variations ( ± 0.3 - 0.5 °F / ± 0.2 - 0.3 °C) can occur, if consecutive measurements are taken. Temperature taking hints · The right ear reading may differ from the reading taken at the left ear. Therefore, always take the temperature in the same ear. · The ear must be free from obstructions or excess earwax buildup to take an accurate reading. · External factors may influence ear temperatures, including when an individual has: - been lying on one ear or the other - had their ears covered - been exposed to very hot or very cold temperatures, or - been recently swimming or bathing. In these cases, remove the individual from the situation and wait 20 minutes prior to taking a temperature.
