The usual default password for wireless devices is four zeros "0000" If that doesn't work, check the manufactures website for a code list. At the very least, Tech Support will tell you what to do specifically. Cheers and good luck. Grim
A list of games that you can enjoy playing with your China Android Tablet PC iPeds<br /><br />Download from here:<br /><br /><a href="http://computersight.com/computers/top-10-china-clone-ipad-epad-android-iped-games-to-install-that-works/">http://computersight.com/computers/top-10-china-clone-ipad-epad-android-iped-games-to-install-that-works/</a><br /><br /><utube src="j6AZib67xqQ">I hope this helps.<br /><br />
Usually there is a pc. of plastic that appears to be a power button but inside of the case there will be an actual button connected to wires that is pushed when you push the button outside of the case. Should be able to use a toothpick to push in on the little circle u see inside of the case. If not you can remove the cover and order the part that is broken. http://www.androidtablets.net/forum/wondermedia-based/12092-android-2-2-via-chipset-7inch-epad-mid-power-button-not-working.html this person dropped theirs and the wires came loose inside of the case.
With the tablet switched off press and hold the volume + and volume - buttons and the power button that should put you in recovery mode where you can do a factory reset
Having the same problem my tablet turns on shows epad then android flashes HELP PLEASE!!!!
This means that your epad's inside screen is damaged and this means that your epad is completely gone. You will have to purchase another one. I had the same problem and i had the choice of another epad or an ipod touch, i chose the ipod touch because it has almost the same features as the epad or even better features. I suggest that you order the epad from a chinese retailer.
