Try this clip I have just found, hope it helps. TRY 0335 OR 0060 PRESS TV ON YOUR SKY TV REMOTE , PRESS RED & SELECT TOGETHER UNTIL RED LIGHT FLASHES TWICE , PRESS TV ENTER 0335 OR 0060 PRESS TV AGAIN THEN THE OFF BUTTON IF THIS TURNS OFF YOUR TV SELECT IF NOT PRESS TV THEN THE OFF BUTTON AGAIN REPEAT THE LAST BIT TILL THE TV TURNS OFF THEN PRESS SELECT ; DONT RUSH THIS BUT FOLLOW THIS TO THE WORD HOPE THIS WORKS FOR YOU . I FOUND THIS ANSWER ON THE WEB IT'S BY AN EX SKY ENGINEER . GLAD TO HELP...
A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
0039.0033. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
