If you have a universal remote just check if your tv is listed in the manufacture menu.if it does look for the code beside your tv brand.it could have more than one code so you have to try all of them.if you find it then first turn on the tv manually. you press down the code search on the remote it will stay light release the code search button.press and release the tv button on the remote.enter the code found on the remote chart that is pertaining to your tv by entering it on the remote manually. aim the remote on the tv push the the on off button try this with all the codes untill your tv cut off. if your tv does not appear on the remote list use the manual code search.which is.. first turn on your tv manually press and hold the code search button until the indicator light illuminates.trhen you release it.press the tv button on the remote.the indicator light will blink and stays on.aim the remote on the tv and press the on and off button continously until your tv turns off you have to do this up to 200 hundred times continouslly.when your tv switch off press enter to store your code.
good luck/
