My steam cord outer covering is all frayed at the iron end and getting worse. The hot pipe is exposed. Is there a replacement hose and cover that is user replaceable please?
Unplug the iron: Make sure the iron is unplugged and cooled down before attempting to replace the cord.
Remove the cord from the iron: Depending on the model of your iron, you may need to remove a cover or panel to access the cord. Look for any screws or clips that hold the cover in place and remove them using a screwdriver. Once the cover is removed, you should be able to see the cord and the connections to the iron.
Disconnect the cord: Use a pair of pliers or a wire stripper to carefully remove the wire connectors from the cord. Be sure to hold onto the wire connectors so you do not lose them.
Attach the new cord: Follow the steps above in reverse to attach the new cord to the iron. Strip the ends of the wires on the new cord and attach them to the wire connectors. Be sure to connect the wires according to the correct polarity (i.e., positive to positive, negative to negative).
Replace the cover: Once the new cord is attached, replace the cover and secure it with the screws or clips you removed earlier.
Test the iron: Plug in the iron and test it to make sure it is functioning properly.
If you are not comfortable or experienced in electrical repairs, it is recommended to have a professional perform the cord replacement. Tampering with the electrical components of an appliance can be dangerous and can cause damage to the appliance or injury to the user.
If the iron is a steam-iron with a steam tank in the base-unit, then steam is carried up the connecting pipe & it will get hot in normal use.
If you put water into the iron itself, then there is only an electric cable connecting the base & it should never, ever get hot. A little bit warm maybe, but never hot.
Best of luck.
You will need to obtain a completely new power cord kit from the manufacturer. If you are not familiar with doing electrical repairs, you may want to have a technician do it. Insulation on the power cord is important for several reasons; especially a method to keep you safe from a fire, electrical burn, shock, etc.
Sunbeam Model: gcsbcs-212
The outlet cord was bad (pinched from falling off the ironing board) inside where the cord goes into the iron.
1. Remove Bottom Sticker
2.Remove 2 Screws
3. Pry off Sunbeam Back Cover
4. Remove 2 screws
5. Pry off Cover
6. Remove Cord Clip (2 Scews)
7. Cut Cord and Strip off ends ( do I cable at a time) Red Circle
8. Crimp back and Test.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
If the iron is still in warranty send it back via the shop where you bought it, the inner wire is frayed and needs replacement, if you know an electrician its as simple as shortening the flex by a few inches and reattaching it again. the inner wires twist with time and become frayed or come loose from connection
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Hi, it sounds like the steam trigger has a broken pin on the end inside the handle. Unplug the unit from the wall and let it cool. I found out that you can remove the main rubber cover by gently prying it up from the front and pivoting it up to the cord end and lifting it off. You will see the trigger snaps in, but look at the finger end going under the microswitch that activates the "Burst of Steam"...it is probably broken. You can get another one from California Electric Service in Concord CA; or you can epoxy a small 3/4" by 1/8" x 1/16" piece of aluminum, bent at 45 degs into trigger hollow, approx 1/4" sticking out to actuate the micro-switch and after a day or two for the epoxy to harden it should work just fine.
