Check this article
http://support.liftmaster.com/articles/How_To/How-to-program-a-remote-control-1484145515533/?l=en_US&c=Brand%3ALiftmaster&fs=Search&pn=1
click on the email support if you can't work it out on the above web site link
SOURCE: how do you program an Overhead Door garage door
Click the button on the overhead unit . it's square it will light up. Click your remote ,it will flash and then it's done
SOURCE: unable to program my new 2009 Altima Hybrid Homelink to my gate
The Learn Button is in a Silver little metal box that is in the opener housing but separate from the opener itself, pry off the case which kinda wraps around the reciever, it will say liftmaster of chamberlain the learn button will be in the reciever
SOURCE: How do you clear and re-enter a new code for wall mounted remote
To change the code you need to locate the smart/learn button which is near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in any 4 digit code you like and press enter.
See if this works for your car.
3. Go to the
Learn Button on your garage door opener. The button is usually next
to the area where the floppy antenna is connected to the motor head.
With Genie it is most often behind the light lens, and an indicator
light flashes red when pressed. With Sears or Liftmaster
(Chamberlain) it is near, or part of, the terminal screw board, and
is a red, green or purple square button with a green, amber or
purple indicator light. Press this learn button momentarily. The
indicator light will turn on and blink if Genie or otherwise stay
lit. For Genie systems, go back to the in-car transmitter button you
programmed and press this button 3 or 4 times, or until the door
starts moving. This should set your in-car transmitter to your
garage door opener. For Liftmaster, Sears, or Linear Megacode press
and hold the in-car button you programmed until the garage opener
light flashes. Your in-car is now programmed to operate your door.
SOURCE: I've got an old wickes
You can also get remote units that connect to the same terminals that you would hard wire a button to. You really do want a later remote, as they all now use rolling code technology. Essentially you have to "invite" a remote and the unit and remote agree on a code. From that time on, the code changes every time that you use the remote (automatically, you do nothing). Way better security, and a guy cannot just run a frequency generator and open your door.
SOURCE: where is the smart learn button on my Overhead
You do not have one. Just went through that myself! Tried differant universals none worked! Must buy the 109130-390
