ASUS P5N-E SLI Motherboard Logo
Posted on Mar 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer will not boot all the time. Getting worse. Have to do a cold boot and it may start up. Boot failure will not recognize hard drive but BIOS will. I changed the hard drive about 6 mths ago. I upgrade to latest BIOS. I checked boot order in BIOS and seemed ok. When computer loads properly it seems to be normal until it reboots itself. currently running win7 64 bit 8 meg ram 600w power supply. I pulled all non-essential compoenents off MOBO and it did not help. I gave it to a repair shop and they "think" it might be the MOBO and the hard drive. I was hoping it was just a BIOS setting. I do not think hard drive is problem. Any suggestions? Any way to test MOBO? Help!
Anonymous
Level 2:
New Friend:
  • Expert 95 Answers
  • Posted on Mar 04, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
95
Questions
0
Helped
46601
Points
320
It doesn't appear to be a RAM or CPU problem. It could be the motherboard (maybe the SATA controller), or the hard drive. There are two thinkg you can try:
1 - connect the hard drive to another SATA port, and change the boot order in the BIOS to point to the new port. If it works then it's a problem of that specific port. (motherboard problem)
2 - connect the hard drive to another SATA port on another controller. If you have the hard drive connected to a red port, try a black port. If it's connected to a black port, try a red port. If it works then it's the controller. (motherboard problem)
3 - try to install the OS on another hard drive and connect just that hard drive. If it works, then it's an hard drive problem, and you can replace that.
Testimonial: "great suggestions!"
Anonymous
Level 2:
Scholar:
  • Expert 87 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
87
Questions
0
Helped
21565
Points
278
from the symptoms you describe, it seems like either your PSU or your MOBO is not working properly. I don't think the issue is HD-related, but you can try to run some test, give a look here to find the tools that best suits your hard drive: http://pcsupport.about.com/od/toolsofthetrade/tp/tophddiag.htm . To verify if your PSU is fine, you can either use a voltmeter (only if you have some experience with electronics and such) by jumpin the PW_ON and GND pin of the ATX cable, or you can run a stress test (like OCCT and such) and see if it can handle your rig (ie, if your PC reboots after a couple of minutes that the test started, it most likely means your PSU is not working). Testing a motherboard instead is quite more difficult: you can either try it on a different working pc or look for sign of burnout and broken capacitators on it. Another thing you could try, is running your pc without its case, ie completely disassemble your pc and then reassemble it on a workbench to see if it works.Let me know if anything works!
Hope it helped,
Franz
Testimonial: "Thanks for the help. I will let you know how it goes."
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Media test failure, no os
Your hard drive is missing from the system. Or, just does not recognize it.
The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
1helpful
Boot failure insert system disk, but it wont load
You need to check both in BIOS by pressing F key during boot. First check to see if HD is there. If OK, then change Optical drive to first boot, save and reboot.
IF MISSING HD -
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
How can I a boot disk system failure on my Asus without a system disc?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
2answers
My friend droped her notebook and now when she turns it on it just beeps and tells her to reboot and select proper boot device.what is boot device?
boot device means anything you can boot from (eg hard drive, CD, flash stick, etc). If your getting that message its most likely because it isn't recognizing the hard drive. You can try to take the back off and make sure the hard drive didn't get knocked loose, but depending on how big of a drop it suffered, it might have broke the glass platters.
PXE-E61 media failure when i start up my computer
The PXE-E61 failure is a failure to boot to the network card, this generally indicates a problem with the hard disk drive.
  1. Boot to the BIOS and reset the defaults
  2. Reseat the hard drive
  3. Boot to Windows CD and run CHKDSK /R on HDD
If the system will not boot to the HDD, but it is seen in BIOS, then the HDD may have an OS issue, if not detected in BIOS HDD likely has failed.
2answers
When i start up my computer (Accer 4230) i get this message "UNDI PXE 2.0, Media test failure, check cable, exiting PXE ROM. The message repeats over and over and it wont start up. I don't have an...
Start the computer and hit the F2 key until you get into the BIOS. When in the BIOS you can see in the Main/general page whether the hard drive is seen by the system. You will see HDD (hard drive) CD-ROM which is the optical disk drive.
If you see the hard drive the look for boot options in the tabs. When you get to boot options set the HDD as the first boot device, save the settings and exit the BIOS.
Hopefully the laptop will restart and boot from the hard drive, thus into Windows.
If the hard drive is not seen in the BIOS then the hard drive has failed and needs replacing.
If you have a BIOS password then start the computer hit F12 repeatedly until you see the boot option menu and choose the HDD.
Regards.
Need an manual every time i turn computeron a message asks for a boot disk!
The computer is asking for a boot disk because it cannot see your hard drive. Check the bios to be sure that the BIOS is recognizing your hard disk. If it is, then you may have a hard disk failure or a motherboard failure.
If you go out to ASUS's website you can download a user manual by putting in your model number, etc...
2helpful
4answers
Problems with my inspiron 1501 details below
The problem your having could be the operating system is damange or the hard drive failed. Try to boot from a Windows XP or Vista CD to see if the drive is recognized.
Regards,
3answers
Windows will not start
Ok ...that message about the PXE is showing up because the computer cant find an operating system on the hard drive for some reason.
Try booting from your Vista DVD ,let setup start then running Start Up repair ....
3. If prompted, press any key to start Windows from the installation disc.
NoteIf your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computers BIOS boot order
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
