It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number) 1. Place food in stoneware according to recipe. 2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash indicating that the unit is plugged in, but not turned on. HOW TO PROGRAM YOUR SMART-POT™ (CONT.) 3. Push the Cook Time button to scroll through the timed cooking options. Push once and the 4 hour light will illuminate, twice and the 6 hour light will come on, etc. Select the time based on the length of time indicated in the recipe. Two time options are usually given. The 4 and 6 hour settings are the HIGH temperature setting and may be used when you want your food done quicker. The 8 and 10 hour settings correspond to the LOW temperature setting and is used for all day cooking. In addition your Smart-Pot™ can be set to the Warm Setting by scrolling through the timed cooking options until the warm light illuminates. NOTE: The Warm setting is for keeping already hot food warm. Do not use the warm setting to cook or reheat food. 4. When the cooking time is completed, the Smart-Pot™ slow cooker will automatically shift to the Warm setting and the Warm light will come on. NOTE: We do not recommend using the Warm setting for more than 4 hours. 5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the wall outlet. 6. For other recipes that give a range of times, select the time closest to the setting on your Smart-Pot™. For instance a recipe calling for cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours. NOTE: If power goes off then power light will blink and settings must be reset. If cook time is changed before the cycle is complete the time will
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
reset to the new setting.
Thanks for choosing FixYa,
Kelly
Low Medium High
