M-Audio Delta 1010LT Sound Sound Card Logo
Posted on Mar 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello good day I have a sound card m-audio delta 10/10 lt while using Windows XP works much now walks using windows 7 then the problems started and the sound gets dirty stories already upgraded the drive by the site of the m-audio and nothing any solution thanks
Anupam Datta
Level 2:
Sergeant:
Champion:
  • Expert 263 Answers
  • Posted on Mar 04, 2011
Anupam Datta
Expert
Level 2:
Sergeant:
Champion:
Answers
263
Questions
0
Helped
34090
Points
618
You need to clear your driver and then refresh your windows 7 updates.It will fix
Windows 7 driver for edirol 2496 pci
I have done some research on this and It would seem that there were never any windows 7 drivers for this Edirol product, However further research has discoverd the information below for a work round
also have the same audio card, bought from ebay this year but have recently upgraded to Win7 64bit from XP home. Luckily after tons of googling I found a forum post on another site by a Spanish guy confirming there is a way to use it on Win 7 both 32/64bit version. You need to download M-Audio drivers (as the original Edirol drivers were also made my M-Audio at the time) for their Delta 1010 soundcard (not the LT version) and point win7 to those drivers as they ARE Win7 compatible, I'm using the 'Windows 7 64bit SP1' v6.0.8 drivers. It does actually work, however the guy reckons that the MIDI functions don't but thats no biggy to me.
Only other way is to buy a Roland RPC 1 PCI card and replace the original Edirol pci card with that but they are rare and expensive but you don't need to because of the 6.0.8 drivers! I get no audio dropouts and the sound is very nice just like on XP.
Why isn't it being detected by my win 8 ?
Try reinstalling the Audio Driver As windows 8 drivers are not available Reinstall the windows 7 driver
http://www.m-audio.com/support/download/drivers/delta-6.0.8
Windows 7 64 bit Ultimate SP1. Nuendo 4.2.3. 32 bit version. Delta 1010 LT Sound card. Just out of the blue I started hearing slight crackle when playing back videos, wav files etc etc. It seems to do...
you might have to remove the sound card and make sure the socket is free of dust restart your computer then reinstall it
windows 7 should automatically find the drivers and install them
click start right click on computer select properties in the left hand panel device manager scroll to
sound and video game controllers if you see a yellow qustion/exclamation mark ? ! or a red X
a newe driver will need to be reinstalled
hope this will help
1helpful
Don`t work on windows 7 crystal soundfusion(tm) Device : there is problem on windows 7 but run good on windows xp
This is a sound card that is no longer supported. Fortunately, sound cards are very inexpensive and easy to install.
2helpful
Hey i am using windows 7 ultimate rtm(x86) 30 days trial ver. I hv an intel original 945 chipset with on board souncard. I downloaded the realtek HD audio sound drivers for windows 7 x86. But only the...
hi, to fix that problem you need to download the exact name of the sound card that compatible for windows 7, if you can't find it, its better to use only your vista or windows xp. it is only compatibility of windows 7 some driver won't of it//
regrads
2answers
Need an audio driver
Windows 7 is an beta version. you cant find drivers for that beta version yet
Good luck to you
Nic
DELTA 10/10/LT INPUT/OUTPUT PROBLRM
Well I guess my problem is a little less important. I have 1-2 3-4 5-? 7-8. I dont know where 6 went. I even checked to see if I could plug a wire into the input and toutch it with my finger to see if I got a vu response, Nothing.
No sound from output 3/4
hi
u can try this , please update the driver update for the same issue and update the driver for the sound device or please unistall and reinstalle the sound drivers on the system, or do systemrestore if it was working some days back .... check the
  1. Click Start , Run , and enter services.msc into the Open field. A services window opens.
  2. Scroll down the list of services and find Windows Audio.
  3. Right-click Windows Audio and select Properties .
  4. Select Automatic from the Startup type dropdown list, and click Start to start the audio service.
  5. Click OK and test for sound.
Acer 5050 (5056) not working with Indigo I/O
Hi Uzo, click on this Acer link to open.
http://support.acer-euro.com/drivers/notebook/as_5050.html
Under MS Windows XP, click the dropdown menu & choose,
Audio Driver Realtek Ver. 5.10.0.5273
A download window will open, click to Save. Creat a folder on you're desktop & name it sound driver. Save the download file into the folder.
If you prefer the MS Windows Vista, do the same as mentioned above.
The downloaded file will be compressed in a .zip format. Use WinZip to uncompress the files into the folder you created.
If you need the program WinZip you can download a free 45 day trial from this link.
http://www.download.com/WinZip/3000-2250_4-10003164.html
It is suggest that you check Add/remove programs & unstall any previous sound drivers before installing Acer's driver software. If you sound still does not function, please run windows update service. Code 10 can mean many different things, including you're system may contain a virus.
Explanation of error codes generated by Device Manager in Microsoft Windows XP Professional.
http://support.microsoft.com/kb/310123
Hope the Acer driver software gets you're sound to work.
Have more questions? Please feel free to ask.
Mike
Top M-Audio Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
