E001 error for FIFA 11 - Means your Graphic card is not supported in playing the game. You need to upgrade your Graphic card which support at least the "Shader Mode 3" function.
Most of the onboard graphic cards does not support this function and you get the E001 error when you play the game. Updating your DirectX or graphic card drivers is no help at all because is a hardware compatibility issue.
Hope it helps.
Your mean is that we can not fix our proplem with updating the driver?
SOURCE: when i try to run
Error Message E0001 = This game requires a shader model 3 (or better) card.
You have to upgrade your current graphic card to a better one to run this software!
***Take note:-
The chipsets used in models NVIDIA GeForce 7300, 8100, 8200, 8300 und 9300, ATI Radeon HD3200, HD4350 und Intel/S3 do not satisfy the hardware requirements
Hope it helps.
SOURCE: when i start fifa 11
E0001 ERROR -> Fifa 11 requires a "Shader Mode 3" or better card. That is error E0001 will be fixed and you can play this game again
You can try updating your graphic cards to the latest drivers from Manufacture Site, update your DirectX to the lastest too. If the problems is not solved, then you have to get a better card in order to play the game.
FYI
Chipsets used in models:-
ATI Radeon HD3200, HD4350, etc.. and
Intel/S3 do not satisfy the hardware requirements.
Hope it helps
SOURCE: E001 ERROR WHILE OPENING FIFA-11
Fifa 11 Recommended Requirements:
CPU with Dual core processor (Core duo 2 or better). Intel Core2Duo @ 2.4Ghz on Windows XP / Windows Vista / Windows 7.
1 Gigabyte of RAM (2 GB required for Windows Vista / Windows 7).
DirectX® 9.0c
Compatible 3D accelerated 256 MB video card or equivalent (**must support Shader Model 3.0 or above). ATI RADEON HD 3870. NVIDIA GEFORCE 8800 GT
If your system does not support the above hardware requirements you cannot play this high graphics games & your get the E001 error.
