Sony KV-27FS16 27" TV Logo
A
Anonymous Posted on Mar 04, 2011
My Tv is going Haywire. REmote , TV buttons, and menu wont work. TV has picture, but changes channels by itself, the "favorites" box keeps poping up too. Can I reset the TV myself?
Anonymous
Level 2:
Scholar:
  • Expert 96 Answers
  • Posted on Mar 04, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
96
Questions
0
Helped
15658
Points
245
Have you tried 'hiding' the remote control? :D My neighbor had this kind of problem, it was the RC that was to blame. pointed it away from the TV and the TV worked fine. If that seems to fix the problem for you, u'll have to get a new RC. if it doesn't, it's likely that the problem is with the TV and you'll have to get it to a repair shop.
2answers
My Samsung PN50C450B1D plasma TV doesn't respond when touching the Menu, Volume or Channel buttons on the TV itself.
Chances are you have a stuck button on the button cluster, what I'd do is remove the connector going to it and use the remote control, with a stuck button the remote won't function properly.
I am trying to get a picture on my tv. Since it was hooked up to a satilite receiver prier, I think the problem is the tv is still on Digatal instead of air/antenna. But I do not know how to bring up...
You will need the remote that comes with the tv if there is no menu button on the tv itself to bring the menu up. Hit the menu button and will want to go to the channel option and change it from digital to analog or even just scan for new channels. But honestly, when working with a satilite box you will usually not use your cable or antenna jack in the back of the tv so you might just need to change the input of the tv to get your channels up.
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
2helpful
When I click chanel up or down the tv says please
For the Dynex ZRC-102 remote control channel switching.
1. Press the MENU button and select SETUP.
2. Go down the list and select FAVORITE CHANNEL MODE and switch it to OFF.
The +/- CHANNEL buttons will then switch channels when pressed.
2helpful
2answers
Lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
2answers
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
2answers
ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
1helpful
Favorites Keep Coming On
Check to see if the lower buttons are stuck. You should feel a 'click' when you depress them. If one of them is stuck... you found the problem. Now you need to fix it. All you need to do is pull on the plastic button just a little to give some spring back to it. Or try a needle with a bit of a hook on it. Side it in the right side of the button and pull the button forward. Just be careful not to pull it to far. Just enough to correct to position.
Do you spray windex on the face of the tube??
Read this artical
http://www.fixyourowntv.com/wifekilledtv.html
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
