HP Business InkJet 2800 Printer Logo
Posted on Jul 30, 2008
Printer problems i have a 2800 inkjet printer that I printes lines verticall and horizontally through images, it is not solid any longer. I did a color calibrated and cleaned the heads Im not sure what line feed calibration is what next?
  • 1 more comment
  • lmphashby Aug 01, 2008
    My error edifyguy, the lines were only horizontal. as for your reply, thank you so much for your efforts.
    i am looking at several photos I printed and quite frankly i can not tell the difference, the lines appears to be consistent regardless of the colors used. it is the same with all photos and the lines match the color that is intended to be in that particular location, however there is a line that is dark followed by a lighter line, so on and so forth for any and every color being printed.
    the line calibration I did more describes the look I am seeing on the paper.
    Also, do you know where I can get parts? one of the little wheel with the spring that feeds the paper into the double side printing to the rear of my printer. This inhibits my ability to do double side printing as it will not catch.
    let me know and thanks for your help
    Linda
  • Anonymous Mar 25, 2014
    jagged edges on plots, calibration of roll feed page advance on the 110. put in new print heads, machine does several print alighment prints prior to working.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jul 31, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
884
Points
Sounds like one or more of your printheads is worn out. They are designed to be user replaceable, and wear out after a certain amount of usage.
Black is obvious, but if the lines are purplish, your yellow head is bad. If they're greenish, your magenta head is bad. If they're reddish, your cyan head is bad.
Vertical lines are very unusual. Can you scan a printout and post it somewhere that we can look at it?
Black horizontal stripes
Black horizontal lines ( page is held Portrait ) ,
where print is affected the print image fails to show behind Line effect but shows in between-
the drum surface has been damaged ( likely wear and tear) and can no longer maintain an even layer of electrons due to leakage/short
solution:
replace the toner cartridge which houses the drum.
Printing horizontal solid lines across paper - have done all diagnostic testing but still solid lines across paper.
Hi
Well it is possible that the nozzles are clogged. You did good in troubleshooting the issue, normally head cleaning cycle will resolve that, but if it fails and out of warranty. Best suggestion is to get a new one since head cleaning cycle from printer settings will consume a lot of ink and not a guarantee to work in printers behaving like what you are getting when printing.
Thanks for using Fixya!
2helpful
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
1helpful
Printer prints stripes through images
your printer needs to be cleaned. Use the cleaning mode in windows printer HPOFFICEJET
1helpful
Horizontal lines and tones specks around text
Only known causes are a dirty corona wire or a dirty/bad drum. If you know the drum is good, a thorough cleaning of the drum and cleaning the corona wire should clear up your printing.
1helpful
HP Bus Inkjet 2800 won't print 11x17 with Vista
Many people had a similar problem with the Color Inkjet cp1700 B-size printer.
Vista Patch for cp1700 Printer - Fixes Duplex and Large Format Printing
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=2916&
General page with links to the cp1700 and other printers as well.
Vista Duplex Solution - Back Page Upside Down
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=43
and
http://www.vistax64.com/vista-print-fax-scan/172813-cannot-print-wide-format-hp-cp1700-2.html
Another solution that worked for some people was installing the hp deskjet 9800 printer driver.
It appears what you need is a patched .gpd file for the BI 2800.
Try emailing Bob Headrick, who has done these patches. (Thanks Bob)!
Be sure to put Vista and Large Format Printing 11x17 in the subject line.
[email protected] (or see his profile for email address)
Bob Headrick, Microsoft MVP Printing/Imaging
You'd think between HP and MS, they'd have this working right out of the box.
Did they think people would buy a B-size printer so they could hook it up to Vista and then not want to print mainly B-size documents?
They would have had happier customers if they would have included B-size support but left out A-size!
Amazing!
Good Luck
Photo's print with lines through them
Useually if your printing has lines through it it means that the head (where the ink comes out ) is had it & your up for another head. Sorry but useally big bucks I hope it's still under warranty
Horizontal red lines when printing
Horizontal line is carriage axis , while moving its may give line if some dust or resdual ink may be on he carriage base
clean the caping station and cleaning wiper ( place where carriage rests )
if its not resolved please update sample images for same
k24674
Grand Canyon Tech
Grand Canyon Tech
