your computer is being a pig. dont worry about uninstalling your printer, just add another printer and make this one the default printer. you can just ignore the other one...........shimple.
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
workaround. try insert instead of import save to widows instead your software is faulty and cleaning the disc maybe all that is required if not buy another disc yours might be scratched.
Does it happen with ALL the CD's ? or just this one ? If just this one, then probably the CD is corrupt. if it happens with all CD's, then your problem is with your CD-Rom :)
