I am using Cascade powder and the soap is not entirely dispensing, leaving wet clumps in the container and dishes looking like they're not clean.I am using Cascade powder and the soap is not entirely dispensing, leaving wet clumps in the container and dishes looking like they're not clean.
Inside the soap holder there is a small spring and sometimes that comes under causing it not to open during the wash. If that is fine and you are using liquid soap try pulling a cople glasses of hot water on the latch and give it good clean because it soemtimes gets jammed up. Anymore questions give me a shout.
Check if drain filter is clear and drain pump is working properly. Also remove soap conditioner tray and check if you have black residue inside the soap/conditioner dispenser. Sometimes this can prevent water from entering the conditioner tray.
We had a similar problem with water coming out of the soap dispenser
when the washer was run. I assumed that it was a problem with the water
draining as everyone else posted here. I took off the front panel, got
rid of the junk and drained it. Although this was great, it did not
solve the original problem. It turns out that there was a sock stuck in
between where the water comes out of the soap dispenser and in to the
main compartment. Pulled it out with a needle nose plier and good to
go. Thanks to everyone for their input here.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying... Dishwasher Spray Arms not Spinning
If the DW does not drain the pump could be clogged or has failed. That would also cause the spray arms not to rotate and not circulate water to dissolve the soap or clean the dishes
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Symptoms: Dispenser lid is open. Caked powder at (what would be during normal
operation) bottom edge of soap dispenser or caked powder fallen onto
dishes or dishwasher bottom. There may be loose powder in rest of
dispenser or spilled down inside door or onto dishes underneath
dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many
dishwashers the top tray has an indentation as wide as the lid of the
dispenser. This allows the top tray to be as large deep as possible
while still allowing space for the dispenser lid to open. People often
pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery
or crockery prevents the lid from opening all but a few degrees. Some
water will splash in but not enough to wash out the soap powder. The
soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly
open, will of course swing fully open and you'll be convinced that the
lid opened normally during operation. If this is the problem then if
you're very careful and open the door very slowly you can actually hear
the lid flip open. Also, depending on when the lid opens, how far it
opened during operation and how fast you open the door you may find soap
powder spilled down to cover the dishes at the front or down the inside
of the door. This happens when you first open the door and obviously
there couldn't be loose powder there if the powder had emerged while
there was water washing around. Seeing the lid open as you open the door
is a lot harder but can be done on some machines.
OLDFIXER was exactly right ! I had water gushing out of my LIQUID detergent tray. I removed the tray by pushing down on the flexible tab at the back of the tray and when I had the tray out I discovered A LARGE AMOUNT OF DAMP powder detergent caked up on the inside. I removed it all and sprayed some hot water inside AND ITS COMPLETELY FIXED !!! GOD BLESS OLD FIXER.
One way or another - you're going to have to get that comforter into a spin cycle to get the water out of it. Otherwise it won't dry out until June. If there's excess soap when the cycle finishes, run another full wash without soap. If the washer won't drain properly with the comforter inside, you have another problem altogether.
powder
Are you using liquid soap or tablets?
