RCA F27442 27" TV Logo
Anonymous Posted on Mar 03, 2011
Hi when i plug my three rca male jack into the three female jacks on the the tv coming from my cable box it doesn't work i dont get a picture from the cable signal. can you help me i have a RCA modal F27442
Anonymous
Level 3:
  • Master 3,400 Answers
  • Posted on Mar 03, 2011
Anonymous
Master
Level 3:
Answers
3400
Questions
Helped
985362
Points
10767
Have you tried changing TV channels to "03" or "04"? for external input.
  • 1 more comment
  • Anonymous Mar 03, 2011
    yes but it still doesn't work
  • Anonymous Mar 04, 2011
    You might try getting into TVs menu and do a "New Setup" function. I'm at a loss if that doesn't take.
    yes
I have a Secptre "55-inch Class 4K (2160P) LED TV (U550CV-U) -- i want to connect a "Hearing Device" (for Hard of Hearing) -- when I connect to the 3.5mm Output Jack, it kills the speaker sound.
Here is an actual helpful answer, no idea why some people put answers on that don't help, I thought this site was to help people!!..all you need to do is get an 1/8" Mini Female to 2-RCA Male Adapter (Ive got a link at the bottom to order one} then plug the 2 RCA cables into jacks that say audio output on the back of your TV and your mini jack from your hearing device into the other end of the cable you purchase and your set to go..its an easy fix for under 3 bucks
https://www.ebay.com/itm/New-3-5mm-1-8-Mini-Female-to-2-RCA-Male-AV-Audio-Stereo-Plug-Y-Adapter-Cable/111871432731?epid=1654089605&hash=item1a0c0e981b:g:lHgAAOSwX~dWkxO~
3answers
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
Where can u buy it?
Just copy this into Google "3.5mm Female to Male RCA Mono Jack Plug" That should bring all sorts of other suppliers up. It doesn't have to be made Cables Unlimited to work.
1helpful
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
On the box, it says I can hook it to the tv, but there's no jack that hooks to the tv....
You need a 3.5MM FEMALE Stereo Jack (looks like a headphone jack receptical) to stereo RCA MALE cord. Then plug it into the RCA monitor or audio out of the TV.
Cheers,
Kevin
1helpful
I have a samsung NC10. I have connected to my TV via the PC cable. I can see the screen but here no sounds. I have connected the red/yellow/white audio cable to the tv. It has a jack plug on the other end....
The cable you are using is a rca audio/video cable. The colors translate to:
  • red=audio,right
  • white=audio,left
  • yellow=composite video
Your laptop headphone input uses a ⅛′ (3.5 mm) mono and stereo (TRS).
You need a Stereo 3.5mm mini phone plug male to 2 RCA female connectors.
I’m happy to assist further over the phone at https://www.6ya.com/expert/marnin_498840f315fe3361
1helpful
User manual
On the back of your box you should have Video and Audio output jacks. If you are using those now then you will have to go Best Buy ect.... and get ( 2 ) RCA Y adapters. ( single male, double female ) The single male will plug into the L audio out and the other single male into the R audio out. The cables that used to be in those will plug into 1 each of the female end. Now take your audio cables from you surround sound and plug them into the other female ends, then connect the cable to your surround sound Audio In and that's it. OH, don't do anything with the video cable.
If your not using the jacks on the back of the box then just plug your surround sound cables into the Left and Right audio Out of the box and your done. Don't forget, what ever station your watching on the box is what you'll hear from the surround snd.
Connecting BA735 digital 3.5mm plug with S/PDIF coax jack
The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
5helpful
2answers
Speaker wire to coaxial cable
Yes ! all you have to do is go to radio shack and tell them you want a coaxil to RCA adapter (screw coaxial into wallplate and plug RCA end into sub and your all set!)
Please rate answers and help keep this site FREE!
Thank You
2answers
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
