Welcome to Fixya. Here is the standard Acer Recovery Instructions
1. Power on the machine
2. At the white ACER BIOS screen, hold the Alt key and press the F10 key simultaneously to start Acer eRecovery
3. Once eRecovery has loaded, click Restore to Factory Default Settings
4. Click OK to continue
5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press OK to reboot unit
If this wont work you need to use the recovery cd of your system. Take note that if you do the reocvery process all files will be deleted and the system will go back to default or factory state.
Thanks for using Fixya.
