I have the following unit. Model # TFH 30PRTABB Serial # VL 207740 There is apparently a leak coming down from the Ice Maker, have you had any issues similar. My other question, you manual indicates that thedrain in the freezer may be clogged. I cannot locate, nor can I locate a pan or collector for water. Thanks, Gordon Price
SOURCE: Freezer is leaking water from the inside panel.
Clean the drain tray and drain line in the back of the freezer section, located
behind
the back cover and underneath the evaporator coil. (hint: use turkey
baster with
hot water)
Make sure water drains when you
pour it in. If it doesn't - also clean drain tube on the back of the
unit behind the cover. When done - make sure to put the tube exactly
where it was.
Good luck! :)
Vlad
First Choice Appliance
SOURCE: Model # GSS22WGPH WW
Refrigerator
or Freezer not Cooling or Getting Cold
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
heatman101
Testimonial: "Just want to say thank you. I just read the suggestions and will check them out tomorrow. "
SOURCE: My ice maker isn't getting
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
