Computers & Internet Logo
Posted on Mar 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change text size to be larger - Computers & Internet
Anonymous
Level 2:
Scholar:
  • Expert 64 Answers
  • Posted on Mar 03, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
64
Questions
0
Helped
24893
Points
221
This depends upon what program you are running.
If you mean the Internet, you can change the view settings on most browsers by zooming in (go to "View" in your toolbar).
If it's a Microsoft application like "Word" or "Excel", you can increase the font size or the magnification of the document - again, from the toolbar.
Anonymous
Level 2:
Scholar:
  • Expert 104 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
104
Questions
0
Helped
37515
Points
346
Change The Windows XP Font Size
Right-click an open area of the Windows Desktop and then click "Properties" to open the "Display Properties" window.
Click the "Appearance" tab.
In the drop down list labelled "Font Size", select the desired size.
Click "OK" to save the change and exit the "Display Properties" window.
There are three font sizes to choose from, these being, "Normal", "Large Fonts" and "Extra Large Fonts". As the name implies, "Normal" is the Windows XP default size. To return to the default font size, follow the procedure outlined above and choose "Normal" in the "Font Size" list.
In Windows 7
Go to Start, then Control Panel. Click Display.
Choose one of the following:
Smaller - 100%. This keeps text and other items at normal size.
Medium - 125%. This sets text and other items to 125% of normal size.
Larger - 150%. This sets text and other items to 150% of normal size. This option appears only if your monitor supports a resolution of at least 1200 x 900 pixels.
Click Apply
Anonymous
Level 2:
New Friend:
  • Expert 89 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
89
Questions
Helped
29493
Points
313
If you are using windows 7
  1. Open Screen Resolution by clicking the Start button how to change text size - 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.jpg, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  2. Choose one of the following:
    • Smaller - 100% (default). This keeps text and other items at normal size.
    • Medium - 125%. This sets text and other items to 125% of normal size.
    • Larger - 150%. This sets text and other items to 150% of normal size. This option appears only if your monitor supports a resolution of at least 1200 x 900 pixels.
  3. Click Apply.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 24, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1162
Points
0
How do i change my front size on my lg optimus logic
1 Related Answer
Anonymous
  • Posted on May 29, 2012
SOURCE: change text size
Go to View on your top tool bar. Open up and choose text. open up and pick a size. Hope this helps.
1helpful
How do I zoom on my phone permanently?
What you need to do is to change the TEXT size to larger. If you have an Apple phone, here are the steps to do that:
To change the user interface text size on iOS, perform these steps:
1. Open Settings.
2. Navigate to Display & Brightness > Text Size.
3. Drag the slider to the left to make the text size smaller, or drag the slider to the right to make text size larger.
Apr 25, 2016 • Cell Phones
1helpful
Make font larger on HP1510 printer
What font are you referring to? Have you prepared a document in a word processing program, or added text to an image file, and are disappointed because you want to see the text printed larger? If so, your best solution is to edit the document or image and change to a larger text size. For example, most text documents will normally default to either a size 10 or 11 text which is readable but small. Changing to size 12 or 14 will make the text look larger onscreen, and the text will also print larger. The font name and font size should be displayed on one of your processing program's toolbars, and is easily changed to a different font name or size. If you are simply copying an already printed document and want the text to appear larger, you should refer to your printer's User Guide. If you don't have the User Guide, you can download a free copy at this link:
HP PSC 1510 All in One Printer User guides
2answers
please clarify; what kind of operating system your using? text size of what? application software like word or Computer screen display? for windows screen text you can enlarge by entering control panel-appearance and personalization for win7&win8 - display make item small or larger or by changing screen resolution
1helpful
Text size must be about a 5. Too small to read. How can I make larger?
You can change the size of the text by going to the Start menu, then Control Panel. Click on Display, and then from there you can change the size of the text. It increases the DPI of the text so that it's larger.
2answers
I need to make the font size LARGER.
To print a larger font size, you need to change the size of the text in the document.
For example if this document is a WORD document then when the document is opened in WORD you select your text and then click on the Font size and change it to a larger size.
If it is a new word document, you can set the font size before you start typing.
Don't forget to save the changes in your document.
Printer using small type font size when printing from web pages
I am sorry to say that font size cannot be changed from the All-in-One software. It can only be changed from the application which you are using to print.
you can use Smart Web printing software to print webpages:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00793678&cc=us&lc=en&dlc=en
also, perform the steps below:
Change Text Size in Internet Explorer
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Size" option from the drop down menu. Use the mouse or press the x key.
A sub menu option window will appear containing the following five choices: "Largest", "Larger", "Medium", "Smaller" and "Smallest". "Medium" is the default value.
3. Select from among the five options by using the mouse to highlight or by pressing the appropriate keyboard letter, i.e. g for "Largest", l for "Larger", m for "Medium", s for "Smaller" or a for "Smallest."
The size of the text displayed in the browser window will change in accordance with your choice.
Change Text Size in Mozilla/Netscape 6+
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or Windows users can press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu window will appear containing three sets of options for changing displayed text size:
a. Increase or decrease the text size by small amounts. Select either the "Smaller" or the "Larger" option. Use the mouse to select "Smaller" or "Larger"; alternatively, press the appropriate
shortcut: CTRL - (minus) for "Smaller", CTRL + (plus) for "Larger". The size of text displayed in the browser window will increase or decrease by small amounts in accordance with your choice.
b. Change the text size to one of 7 pre-defined percentages of the default: 50, 75, 90, 100, 120, 150 and 200 percent. Select from among the 7 pre-defined percentages. Use the mouse to highlight your choice or the appropriate keyboard short cut, i.e. 5 for 50%, 7 for 75%, 9 for 90%, z for 100% (the default), 1 for 120%, 5 for 150% or 2 for 200%.
c. Change the text size to an arbitrary percentage of the default, e.g. 300%, 37.5%.
Select the "Other Options" menu item. Use the mouse to highlight your choice or press the o shortcut key.
A pop up input window titled "Text Zoom" will appear.
Type in the percentage amount by which you wish to change the default text size. Click on OK or press the ENTER key.
The size of the text displayed in the browser window will change in accordance with the value you enter in the input field.
These three options may be used separately or in combination.
Change Text Size in Firefox 1.0
1. From the Firefox Menu Bar select View>Text Size>Increase
2. This will cause the text to display on the web page one size larger. However this is a temporary change.
Or use the keyboard:
1. Press Ctrl & +/-, or Ctrl & scroll down/up to increase/decrease the text size.
To make a permanent font size change:
1. From the Firefox Menu Bar,
a. Windows: select Tools>Options. Select 'General'
b. Macintosh: select Preferences.
2. Click on 'Fonts & Colors'.
3. Set the font sizes. Minimum font size.can also be set.
Change Text Size in Opera
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse to make a selection or press the ALT + v shortcut keys. A drop down menu will appear.
2. Select the "Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu will appear containing the following options: 50, 80, 90, 100 (the default), 120, 150, 200 percent. In addition, there are four more options that make percentage increments or decrements to text size: -100, +100, -10 and +10 percent.
Select from among the options by using the mouse to highlight your choice.
* Alternately, use the + (plus) and - (minus) keys on your keyboards number pad, or the Zoom selector in the toolbar.
4helpful
How to increase the font size when printing?
Notepad and Microsoft Word
Please perform the steps given below, if you are printing from note pad nd Microsoft word:
Click on Format.
Click on Font.
Select the desired font under Size.
If you are printing from any browser, then I request you to perform the steps given below to change the font settings in differ browsers.
Following are the instructions to decrease or increase the font size in various browsers:
Printer font size
Click on Format.
Click on Font.
Grand Canyon Tech
Grand Canyon Tech
