Look at the top needle, there should be a rubber like seal that sits around its base. This seals the needle so all the water with pressure goes the the cup. If the seals not there, it can't build the water pressure necessary to go through the coffee inside the cup, thus coming out around needle and out around cup, making it mostly water in your coffe cup.
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
