SOURCE: Olympus DS-30 recorder: memory is full but there are no files to delete
1.Press the FOLDER button to choose
a folder.
Every time the FOLDER button is pressed, it
cycles through folders and the List display will
appear (+P20).
Press the + or – button to choose
the file you want to erase.
Press the ERASE button.
The “Cancel” indicator flashes.
Press the + button to choose
“Erase”.
5
Press the OK button.
The display changes to “File Erase!” and
erasing will start.
“Erase Done” is displayed when the file is
erased. File numbers will be reassigned
automatically
SOURCE: Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
SOURCE: "Memory Full" message flashes, even though all files are deleted
Use the reformat option in the menu to completely erase the memory.
SOURCE: how do i REALLY erase on my olympus ws-300m?
Suggestion is to format the device to remove all unwanted data permanently.
1 While the recorder is stopped, press the MENU button for 1 second or longer. The menu opens
2 Press the + or – button to chooseSubmenu and then + button to “Format”.
3 Press the OK button. The “Cancel” indicator flashes.
4 Press the + button to choose “Start”.
5 Press the OK button. After the “Data Will Be Cleared” message is on for two seconds, “Cancel” will turn on.
6 Press the + button again to choose “Start”.
7 Press the OK button. Formatting begins and an indicator flashes
on the display.
“Format Done” displays when formatting ends
SOURCE: File transfer VN-480PC doesn't work on notebook (Vista)
I had the same problem on XP. The long instructions with downloading updates for wave player did not help. I managed to solve this problem.
Solution:
Go to Control Panel and press Add Hardware. Search for new hardware and allow windows to go on the net to search for the drivers. It will find and install drivers. After that functionality in the Digital Wave Player will become active and you can transfer your files onto pc.
