Question about Vtech Cordless 6041 Phone
"Unable to call try again"
  • 3 Answers
Remove the phone's battery, put it on again. Try to make/receive a call again.
Posted on Mar 31, 2011
  • Alice Smith
    Alice Smith Sep 20, 2014
    This was the proper solution for me! Thank you
  • 59 Answers
The network is bad
Posted on Mar 03, 2011
SOURCE:
Unable to Call, Try Again
The phone line is supplying a certain amount of power. If you open many parallel channels the power is distributed among active phones. The more sets there are the less power each one gets.These are the physical principles behind the limitations on the number of ringers a single line can activate (Ringer Equivalence Number)
As to the need to be using 3 or more sets on the same line and at the same time, I have a hard time understanding that.
For a landline, your phone company can activate 2 numbers, as it can enable A/DSL on your phone line.
Dec 18, 2013 | VTech Communications CS6409 - cordless...
My vtech dect 6.0 keeps saying unable to call try again
I had this happen suddenly on 2 out of 3 handsets with a DS6151 base and DS6101 handsets. Well, what happened is there was no dial tone on either of the 2 handsets on either of the 2 lines and a message appeared on the display "Unable to Call Try Again" after some delay, if Line1 or Line2 button was pressed.
Oddly, the 2 that did not work were the ones normally on "extension" chargers and the 1 that did work was the one on the base unit. That caused me to suspect the base unit .. which it still may have been but the solution was NOT. And, also odd, the handsets seemed to still be synched with the base unit in many respects.
Cycling the power on the base unit did nothing.
These are fairly new units and battery life is generally much longer in my experience.
The Solution:
- Remove the battery from the handset that doesn't work properly.
- Re-install the same battery.
Whatever was wrong, this reset it and the handsets started working again.
Easy fix.
Mar 18, 2012 | Vtech DECT 6.0 Digital Cordless Phone
The telephone batteries are fully charged; however when I attempt to use the telephone I receive a message stating, "No link to base. Move closer to base, try again." The telephone is very close...
Check your user's manual for registration, or RE-REGISTER the handset to the base. In essence, it involves stepping to the registration on the handset, pushing the handset locator button on the base, then saying OK on the handset. They will sync up.
Carl
Feb 10, 2011 | Panasonic Lands Phones
I have Panasonic KX-TG6051M cordless phone. I have been using it for years with no problems. I now get the message:"No link to base. Move closer to base, try again." I have read the user manual...
Hello! Have you re-registered the handsets? If not go to page 39...If you have re-registered the handsets...Pull the batteries for 1 hour...reinstall batteries...allow handsets to set in the cradle for 1 minute then test...
Guru...Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jan 01, 2011 | Panasonic KX-TG6051M Cordless Phone
I have problem in downloading themes from net. when i download themes it give me the warning "already in use" and "unable to install" give me the solution so i could download themes...
  • Goto application manager
  • Uninstall all unwanted applications from that menu
  • It will help you to allocate free space for easy installing
  • Then try again to install.
Hope this was helpful to you.Thank you for using FIXYA and have a nice day.
Nov 28, 2010 | Nokia N95 Cellular Phone
I have lost my contact no from my handset while sync. Though the numbers are available in the system Outlook but I am unable to get it back in my HTC handset when Synchronizing again. What to do?
Nov 27, 2008 | HTC Touch P3450 Smartphone
Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Nov 25, 2007 | Uniden Lands Phones
Vtech Cordless 6041 Phone Logo
3,618 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
