Konami Casino Inc. for Windows Logo
Posted on Mar 03, 2011
I get the following error as soon as i start casino.exe. The application failed to initialize properly (0xc0000005). click ok to terminate the application. please help me. i like konami casino game very much. i have only played the demo version before and loved it very much. so now i purchased the the game cd and found this error.
Ashik Dinesh
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Mar 03, 2011
Ashik Dinesh
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
8770
Points
68
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then would remove them and see if the error goes away. If it does then send the memory back and get a refund!
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention.
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
This error also seen when people have updated drivers for their graphics card. If this happens just roll back your drivers. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
Please Help...0xc0000005 Application failed to initialize properly!!
Please follow the link below to know more about your problem.
http://www.0xc0000005.net/
Good luck...
Hi - I have an IBM Think Pad T43 and everytime I press the power button, it starts, but before the password screen appears, a warning box appears and states: services.exe - Application Error The...
Hi. You need to reinstal windows and drivers.
But if you have a backup use it. Is helping you to save your private data like a.. photo , music , movie , etc.
If you don`t have a backup.. hm.. try to enter in safe mode . if you can`t enter in safe mode just reinstall clean windows. Cheers. ! [Sorry for my bad EN.]
4helpful
3answers
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
STUCK ON LOG IN NOTHING MOVING LEFT OR RIGHT CLICK SCREEN SAYS ERROR IN APPLICATION FAILED TO INITIALIZE PROPERLY 0XC0000005 ISASS.EXE/APPLICATION ERROR
I'd try booting windows into safe mode and disabling windows firewall then trying to boot up normally. I've also heard this may be some kind of a virus.
Application error for GoToMeeting
Thaire765: Please give us a call 24/7 at GoToMeeting support and we'll help you solve the mystery.
I am unable to do anything on my computer
you got virus, and Trojan on your laptop.
need to go buy a good antivirus software. i.e. symantec, McAfee, etc..........
ask the sales person in the store.
scan the laptop.
ERROR CODE
you may use boot to "last know good configuration" try to reboot the computer once again, then while it is initiating, start pressing "F2" until a menu appear, now select "last know good configuration"
this method may depend on what is the type of your motherboard, but usually it is F2 or F5
should you have other questions, just let me know.
Top Konami Video Game Consoles & Games Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Marty Warge
Are you a Konami Video Game Console and Game Expert? Answer questions, earn points and help others
