Olympus VN-480 PC Digital Voice Recorder Logo
Anonymous Posted on Mar 03, 2011
Are there drivers available to download from a VN-480-PC to a MAC? Or any other way to transfer file format to work on a MAC? Thanks! Tony
Ekse
Level 3:
  • Olympus Master 13,435 Answers
  • Posted on Mar 03, 2011
Ekse
Olympus Master
Level 3:
Answers
13435
Questions
82
Helped
3984994
Points
38023
Hi
the voice recorder should work instantly when plugged into the mac, it should show up as a removable stroage device, or a removable drive, like any other external hard drive or usb stick would on a mac.
you don't need a driver to transfer or listen to the recordings from the recorder on a mac.
  • RobzJ Jun 04, 2011
    Hey, having problems seeing the files stored on this device on my PC.
    Tried your Mac solution for this and the device is not visible. Help ?
2answers
Hello, Our designer, who works on a Mac, put all his files on a G-drive Mini portable drive and sent it to me. I have a PC and am trying to get into the drive. It doesn't pop up on my computer when I plug...
Mac files normally have a Mac-binary, or double-fork structure that the PC cannot handle directly. Therefore, it is convenient to convert any Mac file prior to transferring it to a PC or a PC-based network (or to another Mac via a PC or an on-line service) so that its structure will resemble the binary structure of the conventional PC file. The Mac software to accomplish this is called MacBinary (formerly BinHex), and it is available as freeware from CompuServe (GO MACFF, filename BINHEX.HEX). It is also one of the utilities of Stuffit by Aladdin Systems, v. 3.07 or higher, and comes bundled with some communication programs. MacBinary adds a header consisting of a few (usually 128) bytes to the file. This header contains the file type and creator information and a filename that can be different from the original Mac filename. It acts as a "wrapper," hiding the double-fork Mac structure for transfer to and storage in a PC system.
When the file is transferred via modem, the MacBinary file transfer protocol (ZModem MacBinary, YModem MacBinary, etc.) automatically creates the binary PC header for the transfer. However, when the transfer is done via diskette or a typical network (or when a Binary, rather than a MacBinary, modem transfer protocol is used), the conversion from MacBinary to Binary format must be done prior to the transfer in a separate step.
If a Mac file is converted to a PC format, e.g. WordPerfect DOS or Microsoft Word Windows, on the Mac and subsequently transferred to a PC, no MacBinary conversion is needed, since the converted file no longer has the double-fork structure of the Mac. Also text-only files (which have no resource fork) need no MacBinary conversion prior to their transfer to the PC, unless they contain non-ASCII characters (accented and other non-English characters, special symbols, etc.) so really in a nutshell, it will have to be converted before it is transferred to the G-mini disc to be able to be read in PC format, you can try searching the net for programs that will convert MAC to PC but i think it will be very difficult to achieve ...hope this helps please vote and comment thanks
I have formated vn 6200pc through computr how to retain its working
You are NOT supposed to re-format using your PC...you re-format just using the device itself...refer to your operating instruction to try to re-format again or download instructions from www.olympusamerica.com
I recorded meeting minutes to my digital OLYMPUS VN-480 PC voice recorder and want to transfer the recording on it to my Dell Inspirion/1100 laptop. Could I transfer the audio from the headphone jack to...
yes, it is possible. You will connect the earphone jack from your voice recorder to Mic of your laptop. Then you will be needing a wave software on your laptop, download the wave software from the internet, open the wave file, then press play on your voice recorder and the minutes will be recorded into your laptop as a wave files.
But the easiest method of tranferring the minutes is by using the usb cable of your OLYMPUS VN-480 PC voice recorder. If you don't have it you can purchase it, then connect it from your OLYMPUS VN-480 PC voice recorder to the usb of your computer and it will be read like a flash drive.
After that, go to my computer and you will see a drive representing the OLYMPUS VN-480 PC voice recorder, open the drive and you will see your minutes, then simply create a folder on your computer, and copy, paste the minutes into the created folder. And the would be all.
God luck.
I am unable to transfer files from recorder to PC
Make sure you have the software properly installed on the pc, you can download the latest version from olympus page here - software downloads link.
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1175
19helpful
I lost my drive for vn-480pc,
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
3helpful
I have olympus digital voice recoder vn . 480 oc and windows vista, not working, not transfer and not identifiquet the olympus digital... in the list of CD windows vista is out I need of sofware for...
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
26helpful
2answers
File transfer VN-480PC doesn't work on notebook (Vista)
12. Click Next
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
