I was also getting the CO error code, found this in the technical service manual and it fixed my issue:
Resetting the Modifiers and Options to Factory Default To return all options and modifiers to factory defaults, select the timed dry cycle, then press WRINKLE PREVENT, DAMP DRY SIGNAL, WRINKLE PREVENT, DAMP DRY SIGNAL, within 5 seconds. When done correctly, the 7-segment display will show "Fd" and the buzzer will sound before returning to Standby Mode. This procedure does not return the Customer-Focus
Maytag bravos dryer codes error c0?
SOURCE: Maytag Bravos dryer heats but does not blow air.
Maybe that was in addition..they tell us the air flow is blocked and tell us 2 clean our air duct ..but the dryer was blocked on inside..the repair man claimed the belt was off maybe he was blowing smoke..but these are the kind of people they are sending out..trying to blow off as many appointments so they can get off on time.
SOURCE: ''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
